Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint dryer CTD00
Error message empty water Hotpoint CTD00 Dryer, it is not heating!!
Thanks Theresa
  • tandb666 Jan 04, 2009
    Thanks but this was already tried!! will have to strip the machine down what is going on!!
  • Hotpoint Master
  • 3,463 Answers
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
  • Barry Coates
    Barry Coates Jan 04, 2009
    I think you will have to strip it down to access the float chamber and float switch, which is probably causing the prob
Hotpoint dryer ctd00 spinning but no heat. How do I fix it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Hotpoint NWXR473EV Dryer
My hotpoint ctd00 wont heat up
I would suggest that you check the heater and thermostats, these are located behind a removeable cover at the rear of the dryer.
You will need a meter to test them with, you are checking for continuity
Feb 10, 2010 | Hotpoint Dryers
My hotpoint ctd00has stopped heating up how do i
You will find the thermostats located at the rear of dryer.
Remove cover, and you will see them adjacent to the heater element, change them both, even if only 1 is faulty.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Hotpoint Dryers
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint aquarius condenser dryer ctd00 - empty water light will not extinguish after water has been emptied resulting in no heat
The float switch within the plastic unit at base of machine has failed,shorted out Carefully prise the unit open Disconnect and identify the three tags Replace switch and attached lever Examine the insulation on the rear tags as they are very close Reinstate Red light will now extinguish pump will run when float operates hearers will come on
Oct 15, 2009 | Hotpoint Dryers
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Thanks.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint CTD00 condenser dryer not heating up
sounds like a thermostat fault, there is two on these machines and although only one will be at fault both should be replaced
Jul 24, 2008 | Dryers
Dryer cutting main power off after acouple of seconds
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
277 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
