My saltigem keeps turning off display gas detected no flow pump
Our saltigem runs for approx 5mins and then turns of with message gas detected no pump flow
Fills with water and stops giving error message HF
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
  • 1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Oct 20, 2012 | Kenmore Elite 45986 Front Load Washer
Error message HF
Or
Check/Repair:
Oct 20, 2012 | Kenmore HE2 Plus Front Load Washer
Washer keeps blinking FH and stopping
No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Nov 29, 2010 | Washing Machines
I keep getting the HF error message even though I have removed the hoses and cleaned the screens. Is there anything else I can do? The water will run for about a minute then the error message will come on.
Hi There
i just want to say Merry X-mas and a Happy New Year. i found this for you and i hope this will get you in the write direction.
F/H No water detected entering machine or Pressure switch trip not detected.
Or
Thank you for writing to fix ya.
Best regards Richard
Dec 14, 2009 | Whirlpool GHW9100L Front Load Washer
E60 keeps flashing and beep noise. Machine is mid cycle and has come to complete stop
Electrolux E60 - NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
Or
    2. Check for plugged or kinked inlet hoses or blocked or scaled up screens in the inlet valves
Nov 13, 2009 | Electrolux Washing Machines
Hf is showing as an error message. what does it mean?
Details of HF error message and procedure to check and solve the issue is given below:
Or
thanks,keep updated and please do accept and rate the solution.
Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message :fh
(((fh)))
Or
Potential Causes
Replace failed component.((usually the pressure switch and corresponding hoses will need to be replaced))
Jul 30, 2009 | Whirlpool Washing Machines
F H error message
Or
Potential Causes
Jul 13, 2009 | Washing Machines
Error message F - H
Or
Potential Causes
Jul 11, 2009 | Whirlpool Washing Machines
Mid-way stoppage
Or
Mar 26, 2009 | Washing Machines
Washing Machines Logo
374 people viewed this question
Top Washing Machines Experts
