When booting the lap-top up and running any sound files the sound comes out distorted. The lap-top has also become very slow in booting up and opening any programs or files
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Hi, I had the same problem, no booting but only blinking red LEDs. I noticed the harddisk wasn't making any sound that it was working. I changed the original power supply adaptor (12v) with one producing 15v output voltage. And it's working again.
Sounds like your bios options might need to be enabled (boot up sequence) that is if you have a decent operating system otherwise press F2 whilst booting to get into bios pages,familiarise yourself with these pages and when you are confident save and exit changes or reset values to default.--good luck!
You PC has crashed, you need to run a recovery (which will lead to format the partition and reinstall the O/s, that means all your data will be lost).
Restart the notebook and start tapping F11 key,you will come to Recovery Manager, click on Advance Options, and select System Recovery and click on next, select No without backingup the files (as this option most of the times fails). Click on next and wait for 30-40 mins for the reinstallation to get completed.
First u check the laptop Display
if it has display, thn it might be problem ur windows
instead of it.
if computer does not give display thn u check the power adopter of ur laptop.
after all gonig through these steps.even u find all these above steps perfect.
it will mean,
it might be problem of ur hardware.
lets check out it by ur computer vendor.
first u check ur lap in safe mode (press F8 key while booting )if u can't find any distortion of display(sound not working in safe mode) re install the driver soft ware
The sound is contantly distorted problem, and notify you when a new solution is offered.
