Question about Bosch Nexxt WTMC3521UC Gas Dryer
Clean bearing shield in bosch gas dryer - Bosch Nexxt WTMC3521UC Gas Dryer
3 Suggested Answers
  • 319 Answers
SOURCE: Bosch nexxt model gas dryer - screaching noise coming from Bearing shield
call tech support
Posted on Mar 11, 2008
  • 1531 Answers
SOURCE: On my Bosch Nexxt 500
Motor won't work
Lint screen hi-limit (thermal cutout) tripped.
Clean lint screen and clean lint and other debris from front shield, then replace hi-limit. Also check exhaust duct length & # of elbows.
Wire harness failed.
Run resistance or continuity checks to track down broken wire or connector. Replace failed wire harness.
Display shows "E:01" during drying.
Lint filter, air duct or air damper is blocked.
Air leaking past felt drum seal.
Air duct is too long, too small or has too many bends. Inadequate ventilation around dryer (i.e. in a closet).
Clean out filter, air duct and air damper.
Replace felt drum seal. If seal doesn't fit snugly onto drum, wet felt and dry it by running a timed dry cycle for 20 minutes (felt will shrink and fit drum snugly).
Shorten, enlarge, reroute and reduce # of bends in air duct. Move dryer to an area
Posted on Jan 09, 2011
How do I clear all the lint out of the dryer which has gone into the space under and behind and beside the drum?
Hi , it sounds as if your bearings on the shaft of the drum need replacing . The seals that protect the bearings will wear down through time and that leads to the ingress of moisture and starts the rusting of the ball bearings that will start to sound very noisy. One way to check is try and push the drum upwards while empty and let it go see if it clunks you should be able to feel it in your hand .
Mar 05, 2015 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt wtmc6500uc dryer. We receive an e01 error with every load and now cannot run the dryer at all. The vent is less than 5' with one bend, we clean the filter with every load, we've replaced the...
This was a previous post, but it may work for you.
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try.
Feb 12, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch vision 300 gas dryer shows error E12 evry few min. Checked and cleaned lint. Checked exhaust vent. Still E12 every 10-15 min. The dryer is only 6 months old.
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Jan 17, 2011 | Bosch Dryers
On my Bosch Nexxt 500 Series Electric Dryer keeps shutting off and gives the E-01 error we have check the exhaust air duct on back of the dryer and we have vacuumed the inside bearing shield what else...
Motor won't work
Jan 09, 2011 | Bosch Nexxt 500 Dryer
We have cleaned everything--the vent clear out of the house; everything and yet the E001 buzzer keeps going off saying the lint filter is not clean--it is. We are so disappointed in this dryer! Can you...
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Dec 01, 2010 | Bosch WTMC3510UC Gas Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Dryer is louder than before
took the dryer apart and it was filled with lint. Cleaned with vacuum and compressed air. The motor belt pulley was gunked up with hair etc and cleaned that too. Tested and reassembled. Still have the low frequency sound which I take to be bearing sound. It may fail in which case I'll replace the bearings but now the dryer runs much better. The dryer is about 10 years old but now looks like new. Was easy to disassemble so if I have to do it again no problem.
Oct 03, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Nexxt WTMC3521UC Gas Dryer Logo
62 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
