Question about Sony Ericsson T610
Can't Charge!! Here's the deal: One good day, my T610 stopped chargin' I didn't knew what the problem was, so I figured that the dust/dirt accumulated on the AC adaptor's entrance would be the problem, so I've cleaned it up nice and carefully (I didn't wanted to brick it up) and it turns out that after that, it charged again, It kept chargin' for months until yesterday, I figured that the same problem came back again, so I've cleaned it up again nice and carefully, but now It's not charging anymore!!! Charged a little and then Nothing! What this problem could be?? I definetly doubt that my battery has died, 'cause like I've said before, it started to charge previously and then It died slowly... Oh! By the way, when I plug the charger a red light turns on in the center of the phone, but the screen "charging" does not appear, and the charger keeps emitting this barely ear-receptive buzzing noise, it's a very poor buzzing noise, but I've just heard it today... hope you can help me! Thanx a lot.
    Problem Solver:
  • 5 Answers
Try another charger. I broke the plastic that locked into the phone on my car charger and had problems charging. The phone is very finicky about the contacts. Had to replace charger.
Posted on Jul 27, 2007
Why doesn't my tablet charge?
To charge any battery (also on iPhone) both negative and positive poles of the cable and battery need to connect. Check the inside hole of the lightning plug on your iPad while the device is turned off. Most of the time dust and dirt gets clogged in the small connector. This intrusion will inevitably be filled with dirt. Soo much that cable and battery don't connect to exchange current. Take a toothpick and gently check if any dust/garbage/paper/stuff is in there? The places were take our smartphone and tablet are filled with dust and small dirty particles. Like our shoes these mobile companions we wear every day gather dirt. Unclog the connector and try to charge it.
Sep 14, 2015 | Apple iPhone 6
Clutch problems
Release arm in engine is broke.
Jun 06, 2013 | 2003 kawasaki KX 125
Can't move the shifter out of Park after starting engine on my 2000 Taurus. To drive the car, I have to stop the engine, turn the key slightly back, move shifter to Neutral and restart the engine. How...
This might sound strange, but check your stopping lights and make sure they're working. If I'm not mistaken, this model had a stop light "feature" that prevented the car from moving from the park position if required lights were blown out.
The other problem could be your pawl in the transmission. Sometimes, if you don't use your parking brake, a groove can shave into it. This is usually if you are often parking on an incline, in which you should use your parking brake to avoid pawl grinding.
I'm sure you checked for nobs or release buttons, but I figured I would mention it just in case. I know my car has one, but if you drive this car often...I'm sure you knew it was there to begin with.
May 24, 2011 | 2000 Ford Taurus
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 | Watches
Top of freezer and refrigerator stops working for a couple of days then starts working again
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
You may end up having to call a repairman, but hey... This is a 'free' fix and if doesn't work, all you're out is your time. And you'd be surprised at the multitude of problems the accumulation of dirt and lint (or non-working fans) can cause.
Good Luck. Hope this helps.
Aug 27, 2009 | Refrigerators
THE FLASHING LIGHT ON THE DASH BOARD WILL NOT STAY ON ONCE THE KEY IS IN THE INGITION HENCE THE VAN WILL NOT START
the key is at fault, on mine the push bit is missing on key and when dirt or dust get in it the light flashes to resolve i simply blow off dust or wipe off put key back in and it works every time it took me months to figure that out good lukk
Apr 22, 2009 | Renault Dauphinoise PTT French...
Error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 18, 2008 | HP LaserJet 4 plus Printer
Phone code fo T610
the reset code is either 0000 or 5555....all the best
Have a nice day!
tc
Jun 12, 2008 | Sony Ericsson T610
T610
hi..may i know ur mobile's problem plz
Happy to help
Have a nice day!
tc
Apr 17, 2008 | Sony Ericsson T610
Sony Ericsson T610 Logo
142 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
