Question about LG Flatron Computers & Internet
When i turn my computer on i get DSUB out of range 75.0kHz / 60 Hz and it wont allow me in 2 my computer,how do i fixe this issue pls anyone
When i turn my computer on, all i get is dsub out of range,how do i fix it
5 Suggested Answers
  • 34 Answers
SOURCE: I recently upgraded my computer and decided to
try this when boot up start press the f8 then enable vga mode adjust the screen resolution to the standard setting
Posted on Jul 11, 2009
  • 10406 Answers
SOURCE: upon startup a gray box appears reading
Reconnect the "other" monitor.
Right-mouse click anywhere on your desktop "wallpaper".
Click Properties.
Click Settings.
Move the slider to 800 by 600.
Click Advanced.
Click Monitor.
Change to 60 Hz.
Click OK.
Reconnect the LCD monitor.
It should display your desktop, at 800 by 600 by 60 Hz,
including that "Properties" page.
Move the slider to 1280 by 1024.
Click Apply.
If you can see the "prompt", click OK.
If you cannot see the "prompt", wait 15 seconds,
to revert to 800 by 600.
Slide to 1024 by 768, and click OK.
Posted on Jan 04, 2010
budmrtn
  • 11361 Answers
SOURCE: How do I get my
Are you getting balck screen, since this model is known to have bad caps (domed tops) inside:
http://s807.photobucket.com/albums/yy352/budm/LG%201915S/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 17, 2011
  • 12 Answers
SOURCE: when i play games it shuts down the game and comes
Make sure you have the latest video card drivers and drivers for your monitor, which are found here.
Posted on Mar 01, 2011
Can i connect a dvd player on it
only if your dvd player uses dsub or dvi connections. so prob not.
(ive never seen it) dsub and dvi are comouter connections.
youll need a dvd player and monitor with the same ports.
hdmi or svideo are you most likely options (depending on what port the dvd player has. it may only use RCA which is rare on computer stuff)
Aug 22, 2016 | Dell UltraSharp 1707FP 17" LCD Monitor
VGA: signal out of range on Dell1800FP. I see this type of card MSI PM8M3-V (7211010VPM8M3V) Motherboard installed. I know nothing, but would connect on Vga a Dell1800FP. Message : signal out of range
You need to lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution to 800x600. You mave to do this in Safe Mode by pressing F8 during boot.
Sep 30, 2012 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Out of range error on my dell ultrasharp monitor
Need to go to the dell support site for help in finding the right drivers for the Graphics Adapter
Jul 07, 2012 | Dell Computers & Internet
How do I install the driver if I only get "DSUB out of range" on my screen
You get Out of range message because the PC video resolution feeding the monitor is too high for the monitor to handle, you need to boot up insvae mode and set the resolution to 640 x480 then reboot and then reset the resolution to your monitor native resoltion for what ever that is.
Feb 13, 2010 | Computers & Internet
When I connect the moniter to the graphic card geforce 6200 it will not show a display at all. connection to the computer using the regular connection it shows
On both the Graphics card and the monitor, the blue connector is a 15 pin DSub VGA video and the white connector is a DVI video.
With the monitor it should default to the 15pin DSub video input.
If you want to use the DVI video input you need to configure the monitor to use the DVI video input. DVI to DVI give the best picture quality.
If you want to go from 15pin DSub to DVI you need a converter cable.
Try conviguring the monitor for a DVI video input.
Jan 30, 2010 | XFX GeForce 6200 Graphic Card
Doesn'tg work period
Not exactly sure what your saying but, do you have a laptop that was given to you and you was told to use the dsub monitor output(blue trapezoid) on the laptop in order to use it because the internal LCD(the laptop screen) does not work? You can do this if everything is functioning properly. If it doesn't work, try pressing and holding the "Fn" key and while holding it, press the "F7". This toggles between the internal LCD and external CRT displays.
Jan 03, 2010 | IBM Computers & Internet
Optimal resolution problem, edge of desktop outside screen
Your screen probably wont recognise the dvi cable if the dsub is plugged in, you will have to use the buttons on the monitor to adjust the settings to dvi rather than it automatically using the dsub. also, ever tried adjusting the aspect ratio? to make it shrink abit to fit your screen.
Sep 25, 2009 | LG W2261V 22" LCD Monitor
I bought a used samsung 931b 19 inch monitor and it did not come with the cables to hook up to PC what cables do i need?
you need either a dvi-d or a dsub cord depending on whether your computer has analogue or digital outputs. if you look on the back of your computer, dsub is blue, dvi is white. this monitor has inputs for both. the cords are available at you local bestbuy, radio shack, or office depot.
Aug 14, 2009 | Computers & Internet
Computers & Internet Logo
293 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
