02 Taurus stopped blowing hot air. Changed thermostat, flushed system and heater hoses get HOT. Started blowing warm air from dash vents but when switched to defrost it blew cool air. Now blows cool air from all vents.
The system just needs to get all the air pockets out if you switched everything like you said look around where the radiator hose meets where you put the thermostat in, there should be something on the lines of a little nipple with a 8 mm bolt on it i will have to pull up the exact setup of your Taurus but its the same general concept your car is fine you just have a big air pocket , what else you can do is while its cold right now and the car isnt running is to go take the radiator cap off the radiator and see if the antifreeze is low now that the car has cold down since you last ran it. If so feel it up top it off in the radiator and it might hurp it self and remove the air pocket all on its own... If you need any more help feel free im always on here id be glad to help more in detail once you try that and look under the hood for the bleeder ( the thing with the nipple on it) Also if you could please rate me i would greatly appreciate it.
Thanks,
Steve
Heater matrix is blocked you need to clean or replace this unit
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
These will help.
Thanks.
heater blows cool air
