Question about Sony VAIO VGN-NS160D/W Notebook
Sony vaio not charging while charger plugged in
It works if you shake it a bit... and the battery is brand new!
    Novelist:
    Champion:
  • 233 Answers
Seemingly your laptop dc jack is dead. How to confirm it? If you should wiggle your laptop charger on a position to let your laptop charge, it indicates your dc jack is loose. Either replace it or repair it. If your dc jack works well, please check your ac adapter. Maybe your charger is dead.
http://www.chargerbuy.com/laptop-ac-adapter/sony-ac-adapters.html
Posted on Oct 30, 2012
  • 3 Answers
SOURCE: SONY VAIO BATTERY CHARGING
This is not a problem, this is a designed function to increase battery life. To adjust this, go to "vaio control centre", and then power management. Inside this is battery care, here you can adjust the settings or de-activate this function.
Firephox
Posted on Feb 09, 2009
RPFinney
  • 385 Answers
SOURCE: notebook won't turn on or charge (new charger and new battery)
The New battery will not be charged yet, I wouldn't of thought, until you plug it in and charge it.
your problem is with the connector inside the Pc, that the charger connects to,
This has come lose and is now failing,
$150/$200 to repair the connection.
Regards
Richard.
Posted on Apr 22, 2009
marlen56
  • 110 Answers
SOURCE: My battery will not charge on a sony
This information is from Sony Vaio support website:
- Remove the battery from the VAIO and check the battery and the VAIO for damage, dirt or corrosion on the battery connectors
- Re-insert the battery and make sure the battery is well inserted and locked
- If possible, test the VAIO with another battery of the same type to see if the problem is caused by the battery itself. If the problem lies with the battery, you may want to consider purchasing a new battery.
If you are unsure where the problem lies, or have additional questions, please contact VAIO Support.
Posted on Aug 29, 2009
itsourcer693
  • 34 Answers
SOURCE: sony vaio, windows vista...problem is battery error
Try unplugging the power supply from the computer. Turn it off and then after 2 mins restart it. (Plug it back into the computer)
Posted on Jan 05, 2010
  • 56 Answers
SOURCE: sony vaio won't charge new battery
i believe it is a charger issue not a battery issue replace your charger
Posted on Apr 09, 2010
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Battery wont charge and wont work off power supply vaio vgn cr35g ?
i know they are not cheap but it sounds like you need a new battery. is there a light on your charger? is it still on and the same color?
Mar 20, 2013 | Sony VAIO Computers & Internet
My Sony Viao wont stay charged and when i try to power it up, it shuts down by itself at the sign in screen. It wont let me get past the sign in screen,
Are you using a Sony Battery or an aftermarket cheaper version?
If your battery has been changed to a different brand then thats your problem and a whole problem in itself.Not saying there is anything wrong with that, but the Sony ISBmngr.exe file will stop the charging of any battery exept Sony's and put the system into hibernation mode. ( website with Info below)....
If you have the original manufacturers battery then go on.
This is the typical charging-plug, jack, for laptops. Many times the plug itself is bumped over time and pushes on the pin in the center. The charging time becomes very short, if at all, because the connection is broken.Some are completely or because of the position of the wire holding it just right long enough to give a short charge.
32917b9.png With a Voltmeter ,check the output of the charger itself to be sure it is working properly.
Although VIAO has been out for a while & because the model was not listed here the age of the battery may also be in question. If the battery has shorted out and the charging unit & jack are fine then a bad battery that has shorted will cause you symptoms also. Try removing the battery and running on the charger alone.
Here are a couple of sites that I found that deal with Sony VIAO's
1. http://www.ghacks.net/2008/02/02/sorry-you-cannot-use-that-battery-because-it-is-not-made-by-us/
2. http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
3. http://sarabannerman.blogspot.com/2007/04/sony-laptop-battery-mal-ware.html
Oct 04, 2010 | Sony VAIO VGN-CR220E/P Notebook
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
Laptop won't charge
You might need a new battery....you could try removing the battery, plug laptop into ac and restarting. Or you might need a new DC power jack. If you wiggle the cord where it plugs into the laptop, and it starts to charge normally, then the DC power jack needs replacing. http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-s360p-replace-broken-power-jack/
Apr 26, 2010 | Sony VAIO Notebook
Hullo, I spilled wine on my sony vaio
spilling the wine could have caused a surge to your battery or charger either one could be damaged but if your battery is reading full and powers off at random then it is probably your battery and needs to be replaced
Apr 08, 2010 | Sony VAIO VGN-N250E/W Notebook
Sony vaio won't charge new battery
Apr 08, 2010 | Sony VAIO VGN-CR410E/W Laptop
Notebook won't turn on or charge (new charger and new battery)
Regards
Richard.
Apr 22, 2009 | Sony VAIO XG39K PC Notebook
Laptop Charge troubleshoot
This can be due to a dead cell in the battery pack,Could also be the charger is going bad or shutting off prematurely.
Please rate this a fixya
Feb 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-NS160D/W Notebook Logo
101 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
