Question about KitchenAid KHMS145KSS Microwave Oven
Rattling Fan Noise
When the oven is operating there is a rattling sound (sounds like a fan). Generally if the oven is on for a few minutes the sound persists. If the oven is on for a longer period of time the sound stops. However, as soon as you use the oven again the sound is back. THe sound has not impacted any operations at this point.
  • Steve_b Jan 09, 2009
    Great. I was able to trace the problem as you suggested. Well done and thanks!!
    Steve
  • cmalcom03 Apr 08, 2009
    We have the same problem of a rattle with the same model KHMS145KSS. It also comes and goes but oven is still heating.
    Thanks for any help
  • KitchenAid Master
  • 9,086 Answers
If I had to bet, I would say the fan blade assembly is loose on the fan motor shaft.
If so, a spot of super glue where they meet will usually take care of that.
If that's not it, it should be investigated.
It is vital that the cooling fan runs properly, or the magnetron will be destroyed.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
After you look into this, if you still need help, please write back with more details.
Posted on Jan 03, 2009
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
Panasonic rattling noise
magnetron going bad, or fan blade
Apr 22, 2014 | Panasonic NN-S251 Microwave Oven
Safe to use a microwave that is making a loud rattling sound?
It's not a good idea to continue to use it when it's making an unusual noise.
It may be arcing, which can lead to further failure or a fire, or it may be a defective stirrer or fan ,which can lead to uneven cooking or further failure.
$360 for a service call? Are you in Alaska or on Mars? That's insane. Maybe you can contact another servicer in your area?
Jun 09, 2013 | KitchenAid KHMS145KSS Microwave Oven
Safe to Use with Loud Rattling Sound?
Loud rattling when operating
it could be a bad fan or a bad stirrer inside the wave guide. I would suggest you get a qualified technician to come check it out.
Feb 01, 2013 | GE JVM1190 Microwave Oven
Fan makes a terrible rattling noise
The fan blade may have come loose from the shaft or the fan motor bearings are shot. Repair is accomplished by replacing the blade or motor. If the fan is not operating correctly the magnetron will star to overheat and the oven will shut down.
Jun 21, 2010 | GE Microwave Ovens
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Jan 15, 2008 | Neff B7740N0GB Microwave Oven
KitchenAid KHMS145KSS Microwave Oven Logo
785 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
