Question about LG Dishwashers
Lg ldf8812st error code le
I have a LG LDF8812ST dishwasher and its displaying error code LE. What is the problem?
  • 60 Answers
SOURCE: ldF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Posted on Dec 20, 2007
  • 210 Answers
SOURCE: LE error code
Yes this certainly is a sticking point, the inside of the panel is coated with black insulation, when it heats up the wires stick in it and eventually the wires break. The fix is as stated, splice the broken wires together, as well take some of the white insulation and put it in between the wires and the liner.
The errors that can arise from the sticky wires are numerous, LE, IE, etc. EI though is more than likely a siphoning problem. If your unit is noisey during operation, open the door, what is the water level? It should be at the second rim. If not, that is your first clue that the unit is siphoning. Make sure you have your loop in the drain hose.
Sgt 48
Posted on May 30, 2008
MNTECH
  • 1543 Answers
SOURCE: ERROR CODE "LE " ON LG DISWASHER
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
Posted on Aug 27, 2008
  • 423 Answers
SOURCE: ldf8812st lg dishwasher leaking from front door
Thank you for the update. The retrofit kit will probably not only fix your leak but also dry your dishes much better.
I hope the info I provided was useful. Can you take a moment to rate my level of helpfulness?
Posted on Apr 20, 2009
localwonder
  • 6784 Answers
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
Posted on Jun 21, 2009
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
How do I tighten the handle on an LG ldf8812st dishwasher
Try looking at this web site
http://spares.bigwarehouse.com.au/file.php?document_id=5773
Might help
Jul 18, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code LE
Hello and welcome,
locked.
locked.
Remedy:
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Hi I have a LG dishwasher model no:LD-12AW2 which is comming up on the display LE any idea what that means Thanks Andrew
Hi
Searched on google and found error code LE was a blocked filter cleaned tested ok
Sep 09, 2008 | LG Dishwashers
LdF7811ST LG DISHWASHER
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
27 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
