Question about Cameras
How do I charge my Lithium Battery on my Digilife DDV7300 Camera
  • 122 Answers
Did the camera come with a cord with a usb end on both sides?
if it does plug it into your usb on your computer and see if it will charge
Posted on Jan 03, 2009
How many way to charge ?
You cannot charge the battery using the USB cable.
Here are the battery specs for this camers.
Power Battery Form Factor: Proprietary D-LI8 Usable Battery Types: Lithium Ion rechargeable Batteries Included: Proprietary D-LI8 Lithium-Ion rechargeable Battery Charger Included: Yes
Mar 11, 2012 | Pentax Optio S5i Digital Camera
I have the vivatar vivicam8025, how do you recharge it with the cable, I can't find the manual
Charge lithium battery
A. Charge with USB cable
Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED will be off when charge full.
B. Charge with supplied charger
Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
Mar 02, 2011 | Vivitar ViviCam 8025 Digital Camera
I have a DigiLife DDV-1080HD video camera and it will not power up. Have tried charging the batteries and plugged in directly to the outlet, but nothing is happening. What now?
First thing to determine here is if the power supply have a good voltage output (you can measure it with a voltmeter). The battery could be bad, and shorting out the supply, so take the battery out of the camera and try just the DC supply.
Here is a web blog for dead cameras, and things you can try to get it working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If none of those suggestions work, you'll have to have it serviced. Take it into a camera repair shop or contact DigiLife support. Good luck, and hope this helps.
Jan 09, 2011 | DigiLife Cameras
I had my digilife ddv-1100 for approximately three years and It no longer charges. If I pulg the usb in the light comes on but as soon as I disconnect it it goes right back off. What could be the problem?...
Almost certainly the battery. They don't last forever.
MY DigiLife DDV 7000 uses an NP-60 battery. I found some of these on Amazon by searching for "np-60", and paid about $1.50 each. You can also sometimes find batteries by searching on the Camera's model number.
My camera does not charge the battery from the USB lead. I have to use a separate charger.
Jan 05, 2011 | DigiLife DDV-M1 Flash Media Camcorder
My Digilife DDV-A700HD will not power up. I have
I had the same problem with my camera so I had to replace the battery. I could not find the replacement battery that was in the camera. So I did a search and found out that the fuji np- 60 3.7v 1050w worked in the camera. I order the battery and now my camera works just find. I hope this help.
Jun 05, 2009 | Cameras
Digilife DDV-7300 Camcorder - Battery will not hold charge
Not sure of which model exactly your using, but you may check out the web address below.
It appears to be a Chines manfactured Brand, unfortunately alot of these units appear to suffer from a substandard charging system that leads towards a problem with the battery.
The good news is that many mobile phone batteries are often suitable replacements for these to swap out with. I'm picking its probably around a 4.8v or similar flat type battery and is charged either via computer USB connection or through independant charger. A local camera shop won't be a good bet, the shipping to china may out weigh the cost of replacement. I would suggest hunting for a custom battery manufacturer that can supply a replacement battery and hopefully a charger to suit! :o)
As for the on off switch, also a common flaw in the designs, any local video camera repair shop should be able to assist with that part of it. Hope this helps.
http://www.lightinthebox.com/producttags/Digilife-Camcorder-Ddv-C330/
Dec 10, 2008 | Video Cameras
My Digilife DDV-1100
the camera's battery won't charge with the usb cable connected to the computer, only with the 110/240 v charger. Hope I can help
Jul 11, 2008 | DigiLife DDV-M1 Flash Media Camcorder
Batteries
The Lithium batteries that are provided with the camera will supply approximately 200 images. The Ni-MH batteries will provide approximate 100 shots per charge. The B-10LPB Lithium Polymer battery will allow 500 - 700 shots per charge and can be recharged approximately 500 times. B-12LPB Lithium Polymer Battery will deliver twice the power allowing 1000- 1400 shots per charge and can be recharged approximately 500 times. The Alkaline batteries, although can be used, is not recommended due to very low battery life.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
