Question about Water Pik WaterPik& Ecoflow Hand Held Showerhead
Uninstall zucchetti shower head
I need to take the zucchetti shower head fittings off the wall, but not sure how to go about it
2 Suggested Answers
muralme
  • 20 Answers
SOURCE: Hi, Advice please, my shower when on hot comes
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Posted on Jul 16, 2009
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
Jul 27, 2014 | Delta Faucet Home
Changes in amount of water flow from shower head
when he soldered the connections on these pipes.. he may have partially blocked the flow with solder inside..if its restricted up to 50% then its a hell of a pressure loss..hot water is always lower in pressure anyway..also take the shower head and dunk in a clr solution it may have calcium deposits inside the small plastic orafices in it..
Jan 12, 2014 | Water Heaters
Bad shower head
The hose wall has weakened. If it's just a compression fitting in the base of the showerhead, you should be able to simply cut off the bad spot (and maybe a little extra to be safe) and reattach it, but odds are you need to get a new one. Sooner or later the hose wall will crack open and you'll have a mess on your hands.
Jul 13, 2013 | Home
I want to install a new shwer head fixture. I am having difficulty removing the ball joint adapter. any ideas?
You have to remove the whole pipe going into the wall, the ball is not seperate. Use a pipe wrench or something similar to remove it. A new showerhead pipe needs teflon tape wrapped clockwise on the threads and screwed into the fitting inside the wall. Now you can install any shower head you want.
Jul 26, 2011 | Price Pfister 15 Series, Bell Shower Head...
The device the sprayes water from the shower head has broken. The shower head does not unscrew for the shower arm. The shower arm is attached behind the tiled wall. How do I remove the shower arm and...
The shower arm should be screwed into an elbow inside the wall. Unscrew the shower arm by putting your pipe wrench on the arm and unscrewing in a counter clockwise direction ( lefty loosey, righty tighty ) . Measure the length of the arm going inside the wall and make sure your replacement has enough length to reach. Teflon tape the inside end ( the end going in the wall ) and wrap a rag around the new arm, then screw into the elbow going clock wise , stopping when it starts getting tight and with the bend facing downward. Install shower head.
Nov 20, 2010 | Price Pfister Home
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
There is virtually no water flow from the shower faucet we have just plumbed in. there is plenty of water pressure to the sink which is on the same lines. is there anyway to take off the thermostatic...
shower heads are fitted with a 'flow limiter' which is no more than a washer under the sealing gasket where the 'head' fits to the supply pipe.un-screw shower head from pipe,remove 'limiter' reinstall & enjoy.
Oct 17, 2009 | Pegasus Technologies Plumbing
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
Jul 08, 2009 | Water Pik Wall Mount Shower Head
Tub shower combo... newly installed but leaks from shower head when turned on
Some shower heads require a rubber washer that would fit in the opening in the shower head. That may be all you need and would be the simplest fix. Check that first.
Sounds like you need some teflon tape available at any hardware store. The teflon tape should be wrapped around the pipe threads with 2 or 3 wraps and then screw the shower head on to the pipe. If the leak is in the wall, remove the shower head pipe from the wall pipe elbow and apply 2 or 3 wraps of teflon tape to the shower head pipe threads and reinstall to the elbow in the wall. You may need a pipe wrench if the pipe is real tight. Good Luck
Nov 30, 2008 | Dishwashers
Water Pik WaterPik& Ecoflow Hand Held Showerhead  Logo
70 people viewed this question
Top Water Pik Home Experts
john h
Are you a Water Pik Home Expert? Answer questions, earn points and help others
