Question about Nixon Watches - Mens Time Teller Watch in All Black A045-001-00 Time Teller Watch
Taking off the links on a nixon time teller watch A045 001
SOURCE: Nixon Watch band
I tried the hammer plyer thing way back but took a bunch of time and stress, then I took it into a skate shop where they sold nixon watches and they had an actual tool supplied by nixon and all the **** needed to do the job.
Posted on Nov 27, 2008
escapement
  • 2334 Answers
SOURCE: how to set time on nixon scout watch?
Visit: www.nixonnow.com/manuals/nixon_analog.pdf
Posted on Dec 21, 2008
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 93 Answers
SOURCE: Add link to the wrist band on my Nixon
you can find a exper in you real life or in the watch shop..
Posted on Dec 28, 2009
COULD YOU HELP ME PLEASE
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
http://online.nixon.com/us/en/repair-center
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
What size battery does a nixon rerun and a nixon time teller use
....................51-30 I hope this help...
Feb 14, 2015 | Nixon Watches
I have a Nixon Time Teller P Matte white watch , how do you get the discolouration out of the watches strap
take the strap off the watch and soak it for 10mins or more in "oxy" washing stain remover
dont take it back to the pool
if it doesnt work then contact the maker or look for a replacement strap ...
Jan 03, 2015 | Nixon The Time Teller P - One Size - Matte...
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
http://www.nixon.com/manuals/index3.html
Kind regards
Sep 12, 2014 | Nixon The Housing Watch
Brand new watch does not run
the problem is the battery of the watch. it has to be replaced by new one, it is new but it probably sat for a long time in selling shelves that when the time you purchased it, it is out of battery charged. you can bring it to the watch retailer store from where you bought it and you can ask for the warranty of your watch. i hope i had been helped you.
Aug 01, 2011 | Nixon Time Teller P A119211 Watch for Men
I need a couple of extra links to my black and silver Super Rover
mcdevito75 here, BEST BET, look for a small watch repair shop in your area, chances are you"ll have to order these links from Nixon watch.
Jul 12, 2010 | Nixon Super Rover NIX0123
Nixon Watch band
Jul 01, 2007 | Nixon El Dorado NIX0010 Wrist Watch
Nixon Watches - Mens Time Teller Watch in All Black A045-001-00 Time Teller Watch Logo
48 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
