Question about Braun KSM 2 Electric Blades Grinder
Braun coffee grinder spinning but not grinding
The blades spin when I turn it on, but seemingly not fast enough to grind. Is there a way to clean the machine out? Loosen the blades so they spin more freely? Or is the motor just cooked? I would love to be able to fix this. Thank you for your help
  • 4 Answers
SOURCE: blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Posted on Jan 12, 2008
SOURCE: Tassimo one cup brewer
Try cleaning the peircing mechanism (and around it) and making sure it is sitting snug. Sometimes mine comes off when I lift the lid to add a t-disc and this can cause some problems including grinds in the cup.
You may need to get a new peircing mechanism from Braun - if you've only had it for a month they should replace it.
Posted on Mar 05, 2008
  • 4 Answers
SOURCE: Braun KSM1 XXU coffee grinder stuck 'ON'
The little plastic piece is part of the spring tension for one motor brush. It has been re-installed. I no longer need any assistance.
Posted on Sep 25, 2008
co7196
  • 3433 Answers
SOURCE: How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Posted on Jul 13, 2009
SOURCE: when we press are 3107 coffee machine manual
I did fix the problem with help from another web site that I got for FREE. If you want my professional advice it will cost you $9.99.
Posted on Nov 06, 2009
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
Grinder doesnt grind beans although the motor works and the burr spins. I have cleaned it per the instructions and reassembled . Everything seems to fit together properly, but the beans don't seem to be...
I would suspect a log in the outlet shute where it goes into the grinds hopper. Clean it out and then turn the hopper to the coarsest setting to clean it out all together. Coarse grinds are a very good cleaner.
Oct 03, 2010 | Solis Maestro Electric Burr Grinder
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
I have a Saeco Incanto Rondo with a grinder related problem
First step.If the grind is to coarse the burrs will spin to fast sensing no beans.
Solution: The grind needs to be finer. Caution you can over adjust causing the clay burrs to shatter.
Bruce
Gold Roast Coffee
www.goldroast.ca
Jun 14, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Aug 21, 2007 | Cuisinart DGB-600 Coffee Maker
Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Jun 19, 2007 | Gaggia Titanium Espresso Machine
Braun KSM 2 Electric Blades Grinder Logo
49 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
