Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF541 flashing lights
When I turn the machine on, the on/off, final spin, wash enhance, reduced creases, rinse hold, and mini load lights flash manically. Nothing else happens, I can't even turn it off on the off button, only on the wall. Over the last week, if the buttons stopped flashing it would start and run normally. Sometimes during the wash every light would flash but it would still finish the cycle. I have emptied the bottom filter, which wasn't really blocked and now it has gone completely on strike.
Any help out there?
  • mrlopes Jan 05, 2009
    Hi. I have the same problem. I really need support on this. Tks.
  • shones Jan 05, 2009
    my machine starts, makes a noise that sounds like water then the prewash light flashes then it sits on strike till i hold in the cancel button then it just does the same again and again???? am i doing something wrong?
  • 53 Answers
SOURCE: hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Posted on Oct 26, 2009
  • 160 Answers
SOURCE: hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Posted on Mar 21, 2010
SOURCE: Hi our hotpoint wf541 starts its cycle as normal
hi i had the same problem.
its either your filter is blocked or your pump is not working.
after switching the power off, remove the front bottom panel of the machine and unscrew the filter cap on the right behind that panel. check it's intact and clean iside, if not clean it out or replace it and that should fix it. be careful screwing the filter cap back in and make sure its on tight.
to check your pump is working you can pull out the machine and check that water is coming out of the hose by putting it on the pump out / drain cycle after pouring in some water for it to pump out.
Posted on Dec 30, 2010
  • 6277 Answers
SOURCE: hi i got a hotpoint
Sorry but I do not know your particular machine's fault lights coding BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 19, 2011
  • 6277 Answers
SOURCE: i got the reduced creases
(same again!) Hi from retired Englishman in SW France,
John C
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint WF541 problem
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
WF541 Hotpoint
Have the control board checked first
Apr 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
158 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
