Hotpoint WM 22 wont spin
Asked this question a few days ago. Since then have checked and can confirm that it does drain and the water pump is working.
When programme reaches spin it just makes a light chuntering noise but does not spin. Rest of programme working OK.
Help!!
  • tait243 Jan 06, 2009
    Thanks Barkencoa-new brushes did the trick.
  • Washing Mach... Master
  • 3,463 Answers
The first you need to do is check the brushes in the motor.
Remve the screws at rear of top cover, remove cover.
Slacken off the 2 bolts securing motor,and remove belt.Remove 2 screws that hold motor and lift motor up so you can access the brushes..
The brush holders will be either black or white, depress the plastic lug that holds the brush in place, and slide the holders out, remove the wires to the brushes, and check the carbons, if their is less than 2 or 3 mm left, then replace them.
Only fit the genuine brushes, and if you can make sure you fit the black ones, as they are better than the white ones.
Follow the instructions on the packaging on how to release the carbons from the captive position.
Refit motor, and ensure the belt is reasonably tight.
If it still does not work ,then the motor itself could be faulty, check for broken wires in the motor plug and harness.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
    Problem Solver:
New brushes as suggested by one of your contributors
Posted on Jan 06, 2009
Not draining water or spinning?
Hi, The pump may be blocked, machine wont spin untill it has pumped out the water, so the problem is not draining, first check drain hose is not blocked or kinked and then check the pump filter, there will be a hatch or cover usualy at the front near the bottom which you unscrew and you can remove blockage from the pump. Note, there will be some water left in the machine and it will be released when you remove pump cover so put a few towels on the floor or you can tilt the machine back and put a block of wood underneath while you inspect pump. If it still wont work after you have check the hose and pump then the pump may be faulty and need replacing, seek professional help for this.
Aug 05, 2011 | Hotpoint Washing Machines
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have a lg front loader mod-wd-1025fb washer, i moved the other day & i have just connected the machine up to wash & it fills up with water but wont spin it out & just stands still has a OE...
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 29, 2010 | LG WM-2277HW Front Load Washer
The water wont drain from my machine from the wash
What you need to do is check the pump is getting a feed to it
Select a spin cycle, and with a test meter, test for voltage across the pump terminals, if you are getting a feed, and the pump is working ok, then you obviously have a blockage beyond the pump.
If no voltage then could be a broken wire, or a faulty programmer/board.
ONLY CHECK FOR VOLTAGE IF YOU ARE COMPETENT TO DO SO, as it takes no prisoners.
Hope this helps.
Dec 07, 2009 | Hotpoint WMA54 Front Load Washer
My mothers Hotpoint WM 52P will not drain water out or spin???? Does this mean brushes??? poppywitch
no take the sump hose off from the tub off the machine and check for blockages the machine wont spin unless it can drain the water out
Jun 05, 2009 | Hotpoint Aquarius WF220 Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Amana washingmachine wont drain
Check the drain hose and the drain line, if you do not find any obstruction clogging the drain lain, then test the drain pump and the drain pump solenoid.
See also WM won't drain.
Oct 25, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine won't spin
check the pressure switch the unit wont spin unless it knows all the water is out of the unit
May 28, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
