Question about Euro-Pro UV209 Upright Vacuum
Vacuum It shuts of automatically and doesn't turn on again for 45 minutes
  • tinkerjax Apr 07, 2008
    Same thing...My vaccuum will only work for 10 minutes then shut off and wont work again for a long time, but I clean the filters empty the canister?
  • loni_mar Jan 02, 2009
    i have same problem, mine shuts down in about 10 minutes, too. cleaned all filters but didn't matter, still does same thing.
    Genius:
  • 2,985 Answers
Overheating is a possible cause- Check the bag/container is empty Check there is no obstruction in the pipe lines Check and clean/replace filters
Posted on May 14, 2007
My problem/// cleaner turns on for a around ten (10) seconds and then shuts off wait a few minutes and it will turn on but goes off again at ten (10) seconds?????
These units have a automatic resetting thermal fuse near the motor to help to protect it from burning up by running too hot. This will need to be inspected and tested to see if it's holding it's proper temps., if not it will have to be replaced. There should also be an inspection of the machine to detect what was causing the reset to shut down that quickly, so that can be repaired as well.
Oct 22, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Why the vacuum shut off after 3 minutes and the plug is hot
sounds like the motor maybe clogged and over heating. if you can take apart the vacuum and find the motor. if you have a shop vac use that to clean out the dust and debris. put it back together and try it again. if this doesn't work i would replace the vacuum or get it repaired. i would NOT continue to run the vacuum if the plug gets hot after 3 minutes.
Nov 08, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
After from ten to fifteen minutes of use it automatically shuts down but will sstart up again after fifteen minutes.
It sounds as if the motor has overheated at some point and damaged the thermal protector in the motor. Be sure all the filters are clean before operating the vacuum. If it continues to shut down, the thermal protector will need to be replaced. ( Part # 28382093 ) This is a very common problem with bagless vacuums, if the main filter is not cleaned after every vacuuming.
Mar 07, 2011 | Hoover U6630-900 WindTunnel Bagless...
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
Vax infinity 1900 suddenly stopped working now no power gets to it, i've changed fuse still no power.
I have an infinity nv29 that stopped working while I was vacuuming. According to the manual I was supposed to unplug it for about 45 minutes and then try it again. I waited for over an hour and tried it again and it still won't turn on. Any suggestions?
Feb 06, 2010 | Euro-Pro NV31 Infinity Vacuum
Dyson DC17 - the vacuum shuts off automatically
I had the same issue. Got on the phone with Dyson. THe vacuum has a safety feature where if the motor gets too hot it cuts off. You have to leave it for 45 minutes or so and then it will work again. There is an underlying issue though. My problem was the black gasket thats in the debris bin shifted, probably from when emptying i pushed it on something. The black gasket should actually hang off the bottom like a skirt and the 2 groves should fit in on the groves of the gray mechanism. This seal is what provides 100% suction. Because of this..my vaccumm has been accumulating pet hair by the belt which i hear alot of people talking about and especially in the filter area. This is because I broke the seal by not having the gasket in place properly and it wasnt sucking 100%. They are sending me a complete new cyclone unit which has the debris catcher as well as she said its probably so caked up with debris it will never work again 100%. no questions asked they are sending it to me free of charge.
So if you remove the clear cyclinder debris catch thing all you will have is the purple cyclone on top and on the bottom is the black rubber gasket....if that shifted and is no longer hanging off...call dyson cause your vacuum is probably caked up...it will never work properly...they will send you a new part
Dec 29, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Protection light
it might be the bag or the sensor inside the machine.
Jun 28, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Euro-Pro UV209 Upright Vacuum Logo
116 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
