Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
Images not recording
When I tried to use my camcorder recently, it was recording sound, but no images were displayed on the camera screen. However, images were displayed on the camera screen when viewing previously recorded footage. Any ideas how to fix this problem?
    Problem Solver:
  • 5 Answers
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Posted on Jan 03, 2009
GR-D71, no longer records images
CCD (imaging chip) went bad and require replacement. Not a very expensive repair, but has to be done by professional.
Nov 04, 2009 | JVC GR-D71 MiniDV Digital Camcorder
Can't get rid of the screen images for video camera on playback
Hi
If it's like my Canon MVX25i date and time marking then go to the menu, select display setup (or whatever it's called on your camera) somewhere there should be a dialogue which allows you to switch the pesky thing off. I have never used date or time, a very amateurish concept in the first place.
Redars
Scorpigirl
Apr 15, 2009 | JVC GZMG435AG Camcorder
Panasonic nv gs50 camcorder not recording images
Try using a different tape or cd. It could be faulty media.
Jan 05, 2009 | Panasonic NV-GS50 Mini DV Digital...
Recording
I would bet that the camera iris is stuck closed. On some of the Sony cameras, the iris actuator (a small motor-like device) leaks oil onto the two slippery sheets that slide acrossed one another and act as the iris. A qualified tech can pull the iris assy out and clean it. I have repaired many Sony cameras this way. Sony usually recommends replacing the lens assy which is expensive
Oct 18, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Recorded images has verticle lines
No, most camcorders doesn’t work when you recording the image directly on the screen, that means you use your camcorder shot directly to the screen. Maybe the frequency is different, I have tried used RC plugs directly connect to the VCR and recorded, it is much clear.
Jun 15, 2008 | JVC GR-D22U Camcorder
Camcorder Dropped
Sounds like your display screen is broken, but a least it can still record, which is most important; just don't use the zoom feature and point the camera at the action.
Oct 21, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Cant record
Hello, please check this link: http://www.imaging-resource.com/badccds.html According to this you may have the camcorder repaired free of charge. Best regards, Arpi
Jul 01, 2007 | Canon MV700 Mini DV Digital Camcorder
Blank lcd screen
wires have come off the ccd ! canon will fix free of charge,go to canon support
May 31, 2007 | Canon MV600i Mini DV Digital Camcorder
Sound is ok, but do not record images.
I have had the same problem since I purchased mine 4 years ago and it has been repaired 3x and is in the shop for a 4th. I had the extended warranty and Futureshop refuses to acknowledge that it is a Lemon and should be replaced as they don't consider resoldering wires as a "repair". My unit has been in the service center a total of 12 weeks over the 4 years. The service center recommends Sony Camcorders and the Claim center said they get few Sony camcorders so I would say the Canon problem is an issue that is common. Sorry to say. Mike
Jan 08, 2007 | Canon Optura 10 Mini DV Digital Camcorder
Cannot record images
Your model is on a list of camcorders with potentially defective CCD sensors. Sony is replacing them free of charge. Go here for the link and free mailing label: http://www.imaging-resource.com/badccds.html
Dec 10, 2006 | Sony DCR-HC18E Mini DV Digital Camcorder
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
127 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
