Question about Coleman Powermate 3500 Watt Subaru High Perf Engine Pm0433500 Portable Generator
Powermate genarator won't start - Coleman Powermate 3500 Watt Subaru High Perf Engine Pm0433500 Portable Generator
maadgar
  • 44 Answers
SOURCE: where can i buy carburator for a 5500 watts cole
coleman parts are all available from coleman on line, go to their site and click on the "parts" link
Posted on Dec 29, 2009
kel1guy2002
  • 3740 Answers
SOURCE: i can't start my generator
Hi Chuck and welcome to FixYa, I am Kelly.
First off will it fire over if you add a splash of gas to the throat of the carb?
No = you probably have a stuck valve. I just add gas straight to the spark plug hole and slowly pull the recoil through with the ignition off. Most of the time it works to free sticky valve stems after 2 or 3 cycles of adding gas and slowly pulling the recoil through. Then you have to place rags on the cylinder head to catch all of that gas as you pull the recoil through rapidly for expell the gas. WIPE up any residual fuel before attempting a start.
Still no start check compression... If you don't have a compression tester you can make a poor mans tester... Form a paint brush handle to fit into the hole tightly so that is does not extend into the cylinder any farther than the spark plug would. Pull the recoil.... It should LAUNCH the paint brush out of the hole quite some distance and with force.
Yes it fires: SEE BELOW
If this unit had been sitting for some time there are some things you should do: (I note you said you cleaned the carb but the steps below are what need done on a unit that was idle for an extended period)
1. Clean the fuel float bowl
2. Make sure the main fuel jet orifice located in the area where the float bowl nut or solenoid attaches the float bowl to the body of the carb is cleaned. It will have a pin hole in it that ports fuel to a brass tube at the 6 o'clock position in the throat of the carb. The jet is removable but...most of the time you have to modify a regular screwdriver by grinding off some of the wide portion of the blade shank to make it fit the slot in the orifice and the body of the carb. If you use a screwdriver that is too small it will damage the jet and the only way to get it out is to drill it out VERY carefully.
THE PIN HOLE of the main fuel jet MUST BE VISIBLE
3. Check fuel flow to the carb via the float needle, With the float bowl off, place a spray paint can lid under the float and turn on the fuel selector. The spray can lid should fill in about 10 seconds.
If you do not have this amount of fuel flow then remove the main fuel line from the carb and check flow again. If you still have fuel flow problems
a. Check gas tank exit port for obstructions
b. Check feul flow beforr and after the fuel filter (if used).
c. Check fuel flow before and after the fuel shut off / fuel selector Many fuel selectors have a sediment bowl under the selector.. if yours had a sediment bowl remove the bowl and clean out the contents.
4. You have good fuel flow to the carb manifold....
a. Recheck fuel flow at under the fuel float with the float down. It must provide a reasonable fuel flow that would fill a spray can lid in around 10 seconds. If you still have fuel flow problems only at the the float needle remove the float and float needle. Also the main fuel line. Spray carb cleaner from the flat needle seat are to the fuel manifold and then from the manifold to the float needle seat.
5. Float check... must shut off fuel flow as it is raised to level i.e just as it reaches level.
b. Reassemble and test.
This USUALLY does the trick... if not I need the model number of your generator that starts with a "P" so I can look up the engine and carb data.
Given you have already cleaned up the carb I think you may have a valve stem that is slowing the operation of the valve.... or preventing it from closing (
Thanks for choosing FixYa,
Kelly
Posted on Aug 26, 2011
kel1guy2002
  • 3740 Answers
SOURCE: powermate 5000er 10 hp won't
Make sure that the generator is full of oil. It has a low oil level sensor that will ground the spark if the oil is low. If you have filled it to FULL with oil and still have the problem disconnect the low oil level sensor (one wire) and check for spark again. IF you now have spark the oil level sensor has either failed or is dirty. (yes you can clean them with carb cleaner.)
If after doing the above you still have no spark... I need 2 things.
1. the actual model number off of the generator Will start with PM or PMO
2. the engine model number / type / series number off of the engine
Kelly
Posted on Aug 27, 2011
kel1guy2002
  • 3740 Answers
SOURCE: My Coleman Powermate 7000 won't
I not you said you "checked the oil level" My experience with most portable generators is that they must me positioned as level as possible and the oil level must be fully serviced as full as you can get it without oil leaking back out of the dip-stick hole on units WITHOUT an extended dip-stick. Unless those conditions are met the low oil level sensor ends up presenting a false low oil signal and it grounds out the ignition. DO you have Spark at all? If you do have spark and it still does not run respond with the MODEL number off of your ENGINE and I will show you where the main fuel jets are located so you can make sure the orifice is clean.
Some units have a fuel solenoid that presses into the main fuel jet recessed area and shut off the fuel to the carb. This is also an area that debris causes havoc.
Thanks,
Kelly
Posted on Aug 29, 2011
cts237
  • 29 Answers
SOURCE: Coleman Powermate 5000 won't start. Ran it
Check to see if you model has a puel pump, f it is a Brigge & Stratton 10 hp I am sure it does
Posted on Dec 12, 2011
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Coleman powermate generator won't generate
Check rotor again and measure to see if you have DC voltage on the brushes while running. If no then suspect capacitor
Nov 11, 2012 | Coleman Powermate Powermate 5000W...
I HAVE A POWERMATE 5000 12 hp GENERATOR THAT IS ABOUT 4 YEARS OLD. IT HAS BEEN IN STORAGE AND WON'T START NOW. I THINK IT MAY BE A CLOGGED CARBURATOR. WHERE DO I FIND THE SCHEMATICS OF HOW TO TAKE...
I have the same problem on my 10 hp if it set for a long time , I remove the spark plug and put a drop or 2 of gasoline in the cylinder and reinstall the plug and wite and it starts o the first pull
Sep 07, 2011 | Coleman Powermate Powermate 5000W...
Generator only starts when primed then immediately stalls. I 've changed plug,drained gas and cleaned carb. still won't run
Ok, is it a Briggs&Strattion engine? if so it most likley has a fuel pump that works off vacume on it, I had one go bad
Aug 27, 2011 | Coleman Powermate Powermate 5000W...
Where can i get parts for pulley starter for a wolf 1200 genarator as i think the company has gone bust
The engine is LIKELY a standard brand such as Tecumshaw, Brigg's and Straton.
Take it to a small engine repair facility and they can probably get you the part you need. A lot of lawnmower repair outfits will have access to the parts.
May 21, 2010 | Coleman Powermate Powermate 5000W...
I have a generator that will power a drill but wont power 4 strands of lights what could be the problem?
there may be a problem with the way the lights are wired, as this is a powerful genarator and it did power a drill.
Jul 19, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 3500 Watt Subaru High Perf Engine Pm0433500 Portable Generator Logo
53 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
