Question about Brother IntelliFax-2820 Laser Fax
I took off back lower piece
I was cleaning and took back lower peice off now it keeps saying to put paper in and I put it in. I can hear the machine trying to pick it up but I believe I have it on wrong, it was given to me so I took it off and can't remember how to properly place back. I need help with this maybe send me a picture if you can or whatever help. Thankyou.
    Champion:
  • 320 Answers
Ypu may have knocked out the sensor, it will only go back one way good luck
Posted on Jan 19, 2009
I have an Electrolux Washing machine, model FWSB6600FS1 and serial XC73403943, 60 HZ, 10 AMPS top loading The spinner in the middle came off when I pulled a clean, wet down comforter out. Can't...
ok thats your fabric softner dispenser....the flat round disk shape peice goes in first push it rite in agitator until it is seated firm..the other two peices go together snap the bowl shape piece over the cup shape piece..and snap the hold thing ontop the agatator...good luck
Sep 07, 2011 | Washing Machines
HP640 - says paper jam, reset and returns to middle of carriage, says paper jam...etc.... There is no paper jam
Hello T There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | HP 640 Inkjet Fax Machine
Hi I HAVE A SUPER g 3 CANON PRINTER ALARM IS ON MESSAGE THERE IS A PAPER JAM I CANNOT FIND IT AND IF THERE IS A PIECE OF PAPER FRM WHAT I TOOK OUT THERE IS A SMALL PIECE HIDDEN..ANY IDEAS ON HOW TO GET TO...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Jan 31, 2010 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Jan 20, 2010 | HP 640 Inkjet Fax Machine
Paper jam
Hello there
May 15, 2009 | Brother DCP-330C All-In-One InkJet Printer
Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Nov 15, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
Paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 04, 2008 | HP 610 Color Copier
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Brother IntelliFax-2820 Laser Fax Logo
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
