Question about Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch
The second hand on my TAG automatic jumps in 4 second intervals.
This started to happen recently, and I have not done anything abnormal with the watch - same amount of use, under normal circumstances etc. I have had the watch for nearly 7 years, and it has not done this before.
Should I leave the watch and let the spring completely unwind, or perhaps I should use it vigorously for a while to try to "wind it up".
Very grateful for advice.
  • jsapwell Jan 05, 2009
    Very grateful, thank you.
    I shall let you know how the watchmaker gets on.
  • 2,334 Answers
This is very strange situation, as usually this occurs in quartz watches with integrated EOL (End Of Life) only and that is a signal for time to change battery.
In your case I can see the only reason- seconds hand somehow became loose and you need to refit it.
Find your nearest watchmaker and ask to do the job. It's not a big deal, but requires professional skill.
Posted on Jan 03, 2009
I reset the date and now the second hand ticks at
This is END OF BATTERY LIFE warning. Replace the battery and everything will be fine. Rate me plz.
Mar 04, 2010 | Tag Heuer Watches
The second hand is not sweeping on my Tag Huer watch. It jumps in 5 second intervals
Need new battery
if you are in chicago most welcome to come to our shop at
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Aug 24, 2009 | Tag Heuer Carrera Bracelet BA0786 Watch...
Second hand not sweeping but jumps at 5 secs intervals. Appears to be keeping accurate time.
When the second hand moves in short jumps rather than a smooth sweep or a second-by-second hop, it means that the battery is about to run out. Usually, with a week or two the watch will stop working altogether. You should go and have it changed as soon as possible.
Aug 02, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 20, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
My tag heuer aquaracer has a problem: the second hand stops and then speeds up really quickly for about 5 seconds. any idea why/how to fix it?
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4-5 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Mar 11, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Second hand movement
Mar 07, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Watch second hand
I had the same problem with my Tag. Same 4 second jump. It's definitely the battery. I'm surprised at only 3 months, but maybe it sat a while in the display case. Mine was over a year and a half.
Feb 16, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Dec 30, 2008 | Tag Heuer Link Automatic Chronometer...
Navy Seal Luminox watch second hand problem
It is a feature of this watch, it is referred to as the end of life (EOL) feature, it is a way of letting you know its time to change the battery before it dies to the point where it cannot keep time anymore
Oct 24, 2008 | Navy Seal Luminox Dive Watch
Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 21, 2007 | Tag Heuer Link Automatic Chronometer...
Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch Logo
319 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
