Question about Canon imageRUNNER 210S Copier
'How can i attach my ir210s with computer to print'
  • 1 more comment
  • Yousuf Jan 26, 2009
    I have a Canon iR210 Series PSPCL, Copier, Printer, Fax all in one. I am having problem printing from my computer to this printer. I believe I have the IP and gateway address correctly entered. I suspect either IP address conflict or I do not have the right driver installed. Please help. I might need your help installing the correct driver. Thanks.
  • sumanlog May 26, 2009
    Hi Printer Doc,
    WE have recently purchased Canon G3 IR210S copier / printer / fax machine. We have connected printer cable to computer and canon on Windows XP pro.
    Installed Firmware from canon 210 PS PCL5e drivers.
    the problem is we are not able to print. and the port we choose is LPT1.
    Where could be the problem???
  • Jessetech May 11, 2010
    make sure on the side or back you first of all have a place to connect it too. like a parallel port or ethernet for networking
  • 33 Answers
This can only be done if the machine has a print board installed. They no longer are available from Canon. If you look at the side where the paper comes out, towards the back side of the copier, you will see a few removable silver metal plates if no board is installed. If it is, you will see a computer network jack. If it has this jack, then it might be possible to download the drivers from the Canon website. These machines use TCIP printing. Contact me here if you need further info.
Hope this helps,
Printdoctor
Posted on Jan 04, 2009
What year was Canon IR210 manufactured?
That model is pretty old, i havent seen one in almost ten years, i think is discontinued already
May 11, 2016 | Canon Office Equipment & Supplies
Won't print. Power is on, cable attached, computer says it is going to print. Says there is no 2 way communication between the printer and ?
You must firmly insert the cables that connects b/w PC and printer or buy new connector. Or, you may reinstall the driver..
Oct 20, 2012 | HP Deskjet D4360 InkJet Printer
I need instructions on how I can sign an email document that requires my usual signature via an email attachment on the computer screen. doe's it need scanning first i'm not sure how to go ab
Of course, you need to print and scan:-
1-Print the attached document !
2-Write your usual signature on the printed paper
3-Scan the paper by any scanner
Mar 18, 2012 | Computers & Internet
Canon ir210, scanner does not return home and locks up. During copy, scanner tries to go home, and continous away from home. Makes a heck of a noise, scanner rails are clean, allen set on scan drive is...
had this alot your a tech i assume ? if so replace the lens/ccd assy and the ip board if you have a scrap 210 replace the two together that will fix your prob
Sep 14, 2009 | Canon Office Equipment & Supplies
E240 error
it is most likely a burned out scan lamp.
Dec 24, 2008 | Canon imageRUNNER 210S Copier
Canon ir210s gatting error E100
that is a defective laser error code sorry
Dec 23, 2008 | Canon imageRUNNER 210S Copier
Canon IR210s
error code E064 resulting due to transfer roller being dirty or requires replacing . please note transfer roller operates on high voltage .
Oct 03, 2008 | Canon Office Equipment & Supplies
Canon ir210 problem
try to uninstall and reinstall the printer by going to (add remove programs ) in control pannel then restart pc and printer.
Nov 13, 2007 | Canon imageRUNNER 400V Copier
Canon imageRUNNER 210S Copier Logo
147 people viewed this question
old marine
old marine
