Question about Sony KP43T75GRAY 43" Rear Projection Television
Sony 11 blinks
Hi have a sony kv24ls35u. standby light blinks 11 times. any ideas?
    Problem Solver:
  • 11 Answers
Blink code only goes to 8 on this model. Are you sure its not 5 and 6? That would be AKB and Horizontal stop, respectively. Quite likely a flyback transformer on this model.
Posted on Jan 04, 2009
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Posted on Jan 03, 2009
Sony KDF-42WE655 Won't power on. Red Power/Standby light blinks 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sony tv won't switch of standby just flashes
How many times do this standby light flashes at one time switch ON? Count this and make sure, how many times it blinks. These blinks are fault indications. From these number of blinks, you will get an idea about the faulty section circuit inside it. It will narrow down the troubleshooting. If you wish to get more details about Sony Blinking Codes; check this link.
Feb 17, 2013 | Televison & Video
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
11 blinks onSony KV24LS35U
According to the LED error code (11 times blinking) the problem is in "Jungle controller 8 volts" which are not being produce, this kind of fault bit technically difficult to and i suggest you to contact any expert to find the cause of not producing 8 volts supply,
Hope you will understand my sayings,
Thanks for using fixya.
Jul 25, 2009 | Sony Televison & Video
Sony tv kv24ls35u 11 blinks
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Standby Light blinks
it is an error code of the sony maybe there is a problem in it.
Apr 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Sony KP43T75GRAY 43" Rear Projection Television Logo
199 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
