Question about OKI C3200n Led Printer
I have a Epson PX700W which appears to be connected correctly and will print a nozzle check but I can't print a test page or anything else from my pc. I think there may be a network setting I need to change but I don't know what
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Why is my Epson WF 2530 double shadow printing?
Allen, that's very unusual. I've been using a workforce printer for years, and haven't ever seen anything like that.
What paper are you using, and what paper setting in your computer?
When you rand a nozzle test, were the nozzle lines even, or did some look kind of out of place? (a deflected nozzle will give that gosting effect, and "underhead cleaning" is the answer)
May 01, 2015 | Epson Office Equipment & Supplies
Cx4200 does not print black
If the nozzle test doesn't print black, then no black ink is flowing.
Run a "head clean", and do the nozzle check again.
Feb 19, 2015 | Epson Stylus Office Equipment & Supplies
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
My Epson wont print from my MAC computer but it will copy fine & run all the test pages in color & b& w fine. What gives?!? For instance: I tried to print "HELLO" from a WORD...
Maybe its just the connections. check your usb cable if connected properly. or try to use the printer in windows environment to make sure that your printer is ok.
when i searched the epson database for rx580, there is no model like that. Its epson stylus 580
for drivers
http://www.epson.com.ph/epson_philippines/support/eol_product.page?support_name=Epson_Stylus_Color_580
thanks.
eric
Oct 29, 2010 | Epson Stylus RX580 InkJet Photo Printer
Epson PX700w paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Yellow ink not printing after cleaning utilities run; others ok
Your print head is bad. Try cleaning it with a tissue. You may see if you can find a replacement for that printehead.
May 04, 2009 | Office Equipment & Supplies
Printing problems Epson PX700W
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Jan 03, 2009 | OKI C3200n Led Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Black ink
You may want to do the ff. just to make sure your printer is physically functioning.
1. Disconnect the printer cable that is connecting printer to the computer.
2. Turn the printer ON by holding down the POWER button for about 3 seconds.
3. Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4. Press the Up or Down arrows to select NOZZLE CHECK. Press the OK button,
then press OK to print a nozzle check.
5. The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6. To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the Nozzle Check Pattern page does not print, prints out with gaps in it or some of the colors do no appear, then there is an issue with the printer. That means that troubleshooting is required on the printer prior to using printer on the computer.
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
according to the manual, goodluck!!!
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
OKI C3200n Led Printer Logo
228 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
