Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door will only open half way. It appears to be getting stuck when it is opening.
THe garage door will open and close with the remote control, but it will only open half way and it stops.
If you haven't gotten your issue fixed yet... I had the same problem (stopped opening half way when using the remote, went down fine, could lift/close manually fine as well) and this happened on our first cold weather day of the year which was very telling. Anyhow, there are two gauges/dials on your garage door opener unit itself (above, where the light is) which controls how much torque/strength your door uses to open or shut through resistance. I turned mine up some and it now works fine; what likely happened was that the metal tracks or the wood frame condensed in the cold and was providing just enough resistance to stop it when opening - as they have a security device built in to stop if they meet any resistance. Hopefully this helps!
Posted on Oct 29, 2012
  • 3197 Answers
SOURCE: Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Posted on Aug 26, 2009
  • 3197 Answers
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
  • 3197 Answers
SOURCE: Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Posted on Nov 21, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
  • 3197 Answers
SOURCE: garage door is stuck half way up - opener still running
Sounds like your drive gear is bad. It is a white nylon gear just in front of the motor. It will be obvious.
Posted on Dec 30, 2009
I have got a Eazy Lift Mk 11 garage door unit. When i opened it this morning it went just half way and stucked.When i press the remote the motor is not working and the motor is now 4 years old. What c
2 steps for you... first put new batteries in the remote. next trip the door mechanism by pulling on the rope. that frees the door from the chain that operates it. then close and open the door manually to prove the track is ok. then close the door and reengage the tripped mechanism. now press the button on the remote to retry. BTW... most doors will reset the catch mechanism automatically. just press the button and let her go.
Dec 21, 2014 | Building Materials
I have liftmaster door opener 41a5021-1d. Using the remote door closes only half way. how can I repair this problem?
When the motor stops in the down position, pull the emergency release handle. Push the door fully closed by hand then engage the emergency handle. Open the door with the remote and then close it with the remote to make sure the door closes completely.
Oct 10, 2014 | Building Materials
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
Door closes but opens inmediatelly and partially,only 1 foot and a half
With the garage door up pull the release cord to disingage the garage door it self in the up position. You can skip the disengaging step, But,It saves ware and tear on the motor.
Then using a step stool you will find limit adjusting plastic slots/screws on the side of the opener.
The left screw is for garage door down.
I would turn the left screw clockwise 1/2 turn or less. then activate the remote opener. noting which way the latching mechanism moved. and so on.
It may take a few adjustments with this proceedure to get it perfectly closed. Then activate the remote to re-engage the garage door it self.
Also, LiftMaster has a web site that you can check out.
Jul 23, 2011 | liftmaster Garage Door Limit Switch...
The torsion spring on the chamberlin liftmaster garage door 1/3 h.p. broke in half, on the left side, can you fiex this yourself?
This is something you should no try yourself. It can be very dangerous. I wouldn't even do it. Call in an expert.
Oct 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears model 139.655000 garage door opener will open and close but half way up or down the reset button trips. This just occured after the door became stuck on a piece of wood.
This indicates that the nylon gears in the unit have been stripped and need replaced. You can get new ones at searspartsdirect.com. Enter in your model number and a parts list will come up. Thanks BB
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not close door
safety beams are blocked or you have wall console in lock or vacation mode.
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
199 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
