Contributor
- Posted on Feb 14, 2009
Re: how do you remove the blender blades from the...
Press and hold down the center shaft of the blade assembly and lift the blades straight up. You can go here: http://www.ultimatechopper.com/chopper_ul_manual_eng.pdf for a downloadable pdf copy of the user's manual.
When I use the above solution, the blade does not always remove. It is as though the little wires inside do not spread enough to slide over the bulge in the vertical shaft. Do i need new chopper bloades?
Dana [email protected]
Dana
