Question about Murray Garden
Murray riding lawnmower model 40507x8 blade belt is loose. bought a new one and have the same problem. How do you tighten it?
  • 24 Answers
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Posted on Feb 08, 2009
shadtremonky
  • 353 Answers
SOURCE: I have a Murray riding
sound like your spindles may have bad bearing(siezed)
Posted on Jun 20, 2009
lemmingleejn
  • 173 Answers
SOURCE: Replacing the belt on a Murray Riding Lawnmower.
The simplest way, is to take hold the belt, with the tension from the engine pully/clutch mechanism, then to follow the shape around the rest of the cutter mechanism. (You don't have to worry which direction the belt travels,)
Bearing in mind, the tensioner direction.
Then, you will see the correct route, very quickly:)
Hope you can manage, with that.
Posted on Jul 23, 2009
bozcro
  • 867 Answers
SOURCE: need a repair manual for a Murray riding
if belt keeps popping off, it is stretched and needs to be replaced.plz rate-bozcro
Posted on Sep 10, 2009
mowerman1857
  • 389 Answers
SOURCE: how do you change the blades on a 40
Raise up the mower to give yourself access to the blades from the bottom side of the deck. Using a breaker bar or long ratchet and socket, remove the nut (either 7/8 or 15/16 can't remember which) and large flat washer from the shaft. Install the new blades in the reverse order.
If the blades turn while you are trying to "break" them free, you can use a small 2x4 block of wood or a c-clamp on the side of the deck to hold the blade from turning until the nut is freed up
Posted on Sep 27, 2009
Trouble starting Murray 5.o lawnmower
Check for spark. Is the plug fouled? Have you hit anything lately with the blade?
Jul 19, 2013 | Garden
How do I tighten the blade drive belt on a Murray Sentinal Ride on Mower? 145 IC / 102. A drive belt diagram would be appreciated. Regards & thanks for any assistance, Rex
http://www.ereplacementparts.com/ model number Is something like 40566x50c if 2000 model, all your schematics are there. Yours henry
Oct 12, 2010 | Garden
I am looking for a belt placement diagram for a 42" murray riding mower-drive belt.
Use your model number & go online for Murray Riding Lawnmower & search. Most of the time you will find it. If not reply back with model numner & HP (horse power)
Aug 03, 2010 | Garden
I need a diagram for a drive belt for a murray lawnmower
Locate your model number and serial number off the tag under the seat,
GO TO; www.murray.com/manuals/index.cfm?rd=1
Type in your model number and an owners manual/parts manual will download. There will be a diagram in there for drive belt, blade belt and a ton of other useful information
Hope this helps you out
Oct 08, 2009 | Briggs & Stratton Garden
I have a craftsman riding lawnmower and the blade engagement is not starting the blades when i lift it. It feels loose when i lift it.
Sounds like you PTO cable is broken. Part # 175067. It goes from the lever on the dash down to a deck mount and hooks to the idler pulley. When you lift the lever, it should pull the pulley and idler arm towards the rear of the deck to tighten the belt to engage the blades.
Jul 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Jul 23, 2009 | Garden
I need a part no for a murray lawnmower model no.7-39004
The belt number is 37x26. As for a diagram, I have it on micro fiche, but can't find it online. I wouldn't want to try to put that one on. lol I'll see if I can get a copy and e-mail it to you. I have the belt if you can't find it locally.
Jun 26, 2009 | Garden
Murray riding lawnmower motion belt routing
good luck
Jan 17, 2009 | Garden
Garden Logo
43 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
