Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Oil a ao smith motor
Lubricate motor
  • AO Smith Master
  • 1,631 Answers
NO Lubrication available!
They have 'Sealed' bearings.
So if the motor is loud, they (bearings) either need to be replaced, or the motor needs replaced.
Posted on May 10, 2015
    Top Expert:
  • AO Smith Master
  • 4,262 Answers
No way to lubricate unless oil hole on shafts
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Posted on Jul 26, 2009
john224
  • 1378 Answers
SOURCE: A.O. Smith motor for Jacuzzi Spa, 1 HP 2-Speed
Check the line voltage under load first to be sure it is not dropping to low and if it checks out, yes, get a warranty replacement.
Posted on Oct 22, 2009
john224
  • 1378 Answers
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
Posted on Jan 18, 2010
john224
  • 1378 Answers
SOURCE: what do wire colors mean for ao smith dl1056
Thank you for posting your question here on Fixya.com.
White is common, Black high speed, blue medium speed, red low speed; Brown wires are for the capacitor; The remaining 4 are for selecting the rotation.
For details look at the AOSmith print here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 31, 2010
Lubricate ao smith motor
If there's no grease fitting (ball bearings), remove the endbells and manually force grease into the bearings. On sleeve bearings use oil (2in1 oil is ok).
Dec 08, 2013 | A.O. Smith Heating & Cooling
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Motor is frozen.
Unlessyou can find an HVAC shop with a NOS motor for this unit you will notfind a drop in replacement. Even if you do get lucky and find a NOSmotor be prepared to pay nearly as much for it as you would a whole newevap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It'sstill a little spendy, especially if you want two speeds like theoriginal motor had, but you can get out for $80 or less if you'rewilling to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basicallywhat you're looking for is a "48 frame", 1/8 hp, direct drive,110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to giveyou flexability when mounting), "totally enclosed" or "open drip-proof"housing (NOT "open"). Rotation can be either CW or CCW as you can mountthe motor on either side of the housing and some motors are reversable.If you've got the skill to custom make some mounts then you canprobably fudge some of these specs. The ones you can't change are the1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assemblysimply can't be made to go much faster in that housing and if you tryyou will overheat the motor and burn it out very quickly (trust me onthis one!). Most of the cheap motors I've found are 208-230v and I justdon't see the point in having a small 220v PORTABLE evap cooler, that'sjust dumb.
After a LOT of online research I've found thefollowing motors that would be a suitable replacement, with all theabove mentioned specifications. I'm sure there are more, but crossreferencing this information for someone not in the business is trickyand time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
Isuppose that if you found a smoking deal on eBay for an "Open" typemotor you could try it, but I doubt it would last long and make damnsure that ****** is grounded well.
Jul 17, 2010 | AdobeAir Evaporative Cooler Direct Drive
Jul 12, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
119 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
