Question about Dometic Refrigerators
Dometic RM1350 refrigerator icemaker not working
Icemaker does not work
4 Suggested Answers
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
milten1
  • 1304 Answers
SOURCE: Refrigerator icemaker won't work and refrigerator fills with wate
check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Posted on Oct 06, 2009
rickyrt441
  • 4399 Answers
SOURCE: What does the diagnostic code "F" mean ion a
What is the number after?
Posted on Feb 26, 2011
I have a rm1350 Dometic refrigerator. The temperature seems to be creeping upwards regardless of how high I set the temperature. I think I need to replace the power module board.
see if inside sensor has fallen if ok try with thermistor disconnected if ok replace if same board or cooling unit is freezer ok
Aug 25, 2017 | Dometic Refrigerators
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Dometic Refrigerator 2301
if battery ok check convertor or voltage to unit if under 10 volts wont work
May 14, 2013 | Dometic Refrigerators
Dometic cr-50 refrigerator stopped working
check outlet power on back if ok check fuse if ok check 12 volts at power board
Mar 08, 2013 | Dometic Refrigerators
The freezer seems to be working fine but the
If you want a service manual for a Dometic Brand click on the link below. They are good people they will help you.
http://www.gasrefrigeration.net/dometic_manuals.htm Aug 06, 2009- If I can help you let me know, I work and talk to Dometic a lot, Thanks Sea Breeze
appliancepartsse@yahoo.com
Aug 05, 2009 | Dometic Refrigerators
Mar 31, 2009 | Refrigerators
Dometic refrigerator inconsistent temperature
Yes the clearances on gas absorption frig is critical. Not to say there is not another problem. Is the thermister attached to the frig fins?
Mar 01, 2009 | Dometic RM2852 Refrigerator
Refrigerators Logo
49 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
