Question about NetGear WGR614 Wireless Router
Low signal (amber Light0
I have just tried to install my NETGEAR WGR614 v9 .
have followed all steps but internet stays on amber indicating a low signal. also cannot conect to internet while router is attached.
    Genius:
  • 1,913 Answers
Restrt your wireless router.
Posted on Jan 03, 2009
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
How do I resolve my internet port light being amber on my wgr614v7 netgear router
Recommend that you go one step at a time.
1) unplug the wireless router.
2) reset your Cable modem or DSL modem. Wait until the lights show the Wide area network or WAN is working correctly before applying power to the Netgear wireless router.
3) After a minute or so, its signals should change from amber to bright green.
Repeat if necessary. If this doesn't provide the connectivity that you need, a call to your Internet Service provider may be necessary.
Sep 06, 2010 | NetGear WGR614 Wireless Router
I have a Netgear Wireless G WGR614 v9 Router. I
It seems that your Internet download is fine but the issue is with the uploading. Try to switch of the router for few min. Remove all the cables out and press the Power button for 10 to 15 sec and replug the cables
Check the internet connection.
Check connecting to the face book or other web pages abd try uploading the small image first, If its not working .check the upload and download speed www.speedtest.net. and complaint to ISP to increase the Bandwidth
Check the bu
Jun 03, 2010 | NetGear WGR614 Wireless Router
My wgr614 v9 is slowing my internet !
well sir in this case please upgrade the firmware of the router to the latest one. This link will help you out in upgrading it:-
http://kb.netgear.com/app/answers/detail/a_id/11974
In this link you will have installation instructions just follow them and your router will give better performance.
Nov 24, 2009 | NetGear WGR614 Router
My wireless router wont let me connect to the internet, the internet light on the unit is amber. My unit is netgear WGR614
When the router sees an ethernet connection on the WAN, it gives an amber light until it links to the internet. So, either it's a DSL and you need to set the PPPoE properly, or it's a cable connection and you need to configure it with the DHCP or IP address.
Check your ISP's modem instructions carefully and reconfigure.
Carl
Nov 20, 2009 | NetGear WGR614 Wireless Router
Xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Firewall and Nat router configuration for BitComet
Has it ever worked? If not, run the disc that came with it. And what yellow light exactly do you speak of? Are the proper cables connected to the proper ports?
Mar 29, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Trying to install netgear wgr614 wireless router. instructions indicate to shut off modum. this is not an option for us. how can this be by passed?
im pretty sure you will be fine if you bypass that step, or simply disconnect the modem from your router during that step.
Dec 30, 2008 | NetGear WGR614 Wireless Router
Problems regestering
Someone have, most likely, allready had the router connected to the internet, - and registered it, then changed his mind and returned it to the shop.
You do the same, - no repair is needed, you just want a NEW router.
regards
/Teis
Nov 29, 2008 | NetGear WGR614 Router
NetGear WGR614 Wireless Router Logo
152 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
