Question about Maytag MFD2561HE Bottom Freezer French Door Refrigerator
Maytag mfd2561he bottom freezer
My refrigerstor isn't cooling, but my freezer is fine.
  • 2 more comments
  • Anonymous Apr 26, 2008
    Refrigerator is not working at all while the freezer is fine.
  • jdhyun Jul 12, 2008
    I have the same problem. Did you notice if the white vertical bar between the doors is also very hot? The temperature in my refrigerator is hotter than the room it is in. I waiting for the serviceman to show up.
  • mikeb714 Aug 16, 2008
    My problem is identical, but my model number is slighlty different. I havve a MFD2560HEB, circa 2005. Can I hope that the solution you posed here is likely to work for my unit too?
  • smcteague Nov 02, 2008
    My problem is identical, vertical bar is hot, freezer works fine and the fridge is not getting cold at all!!
    Problem Solver:
  • 4 Answers
I had the same problem. I removed the rear panel of the freezer (4 screws), removed ice maker, and found the evaporator fan that blows cold air from the freezer to the refrigerator was bad. I removed old fan and began calling around for the replacement part. Turns out the original encased fan motor went bad because the motor was encased and condensation caused the motor to go bad. The new motor came with brackets and new unenclosed motor. Took 1 screw driver and about 1-2 hours of work. Make sure power and water is off before working on unit.
Posted on Jul 22, 2008
Frig stopped working but freezer is good? Help... I am handy.
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 24, 2011 | Maytag MFD2561HE Bottom Freezer French...
My refrigerator is not staying cold...this just started to happen yesterday...it is warm today? The freezer is working fine? Help
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 24, 2010 | Maytag MFD2561HE Bottom Freezer French...
Refrigerator not cooling,compresser comes on but goes off after about 5 seconds
http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Nov 17, 2010 | Maytag MFD2561HE Bottom Freezer French...
How do i remove the bottom freezer drawer
You should be able to pull the bottom drawer out, lift and pull all the way out.
Becareful it doesn't drop on your foot.
Dec 31, 2009 | Maytag MFD2561HE Bottom Freezer French...
My refrigerator won't cool (freezer still working)
The temp sensor is the most likely cause of this problem. However, you have other possible options that you can test and check:
likely the problem with your fridge is a bad dumper control. This is a part which operates with the air flow from the freezer into the fresh food compartment.
The dumper control is located in the in the upper left corner in the fresh food compartment.
Sep 21, 2009 | Maytag MFD2561HE Bottom Freezer French...
Freezer works perfectly...fridge just stopped being cold..
Do you hear the fan in the freezer ? If not , then your evaporator motor is the problem . If fridge gradually stopped getting cold , then possibly defrost problem which is another route .
Jul 11, 2009 | Maytag MFD2561HE Bottom Freezer French...
Freezer Works Frig Stays at 70
Wow, pay for the Premium Assistance Plan to get a quick solution ! I fixed my issue but thanks for the help ! I went to a FREE online forum and got my fix.
Mar 25, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag MFD2561HES not dispensing water or making ice?
Hi. is your Maytag on the recall list? Do a google search. You may by one of the 1.6 million owners affected. If this solution has assisted you, please rate it. ricardok45
Mar 13, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Drcool
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Temp control pad does not work
if you can replace the temperature control pad then that is the answer. it is stuck open.. does not closes as the temperature of the cabinet cools down.
Nov 18, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag MFD2561HE Bottom Freezer French Door Refrigerator Logo
506 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
