Question about Viper Responder 2Way Security System 5002
HOW TO RESET VIPER 5200 after being zapped , ALARM STOPPED.WORKING
Alarm was zapped by my bitwritter by accident. Now nothing works. Both remotes are not recognizes. Can't get valet to work. There is power to the unit. But nothing works.
5 Suggested Answers
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
bunnydawg
  • 5158 Answers
SOURCE: VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Posted on Oct 19, 2009
  • 103 Answers
SOURCE: I have what i believe
There is a green and blue wire on a white colored harness. You will need to verify that these wires are connected to the lock and unlock wires in the vehicle. This green and blue wires are on a 3 pin harness plugged into the alarm.
Posted on Aug 21, 2010
  • 1455 Answers
SOURCE: So I have a viper alarm system in my car and
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Posted on Oct 08, 2010
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
Alarm won't turn off
the valet key doesnt have a transponder chip in it, so it will allow physical turning of keyways and operations, but will not disable the alarm and often wont disable the immobilizer.
sorry to say i think you will need to get an autolocksmith , or main dealer to get you a functioning key with transponder chip mapped to your cars rfid system that will allow alarm to be enabled /disabled
Mar 23, 2017 | 2000 Volkswagen Jetta TDI
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
Somehow buttons seem to have been pressed on my remote and now there are 3 "z"'s that have appeared on the remote and I have no idea how to get rid of it. My remote now doesn't make a...
Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
The remote start and alarm system will not work when in valet.
Aug 06, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Aug 21, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
Jun 01, 2010 | DEI Valet Keyless Entry System
Viper Responder 2Way Security System 5002 Logo
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
