Question about Cobra Electronics CXT85 Two Way Radio
How to turn off the beeping sound on cobra walkie talkie.
Every time i speak, at the end, it makes a loud beeping noise. how do i turn it off? it doesnt have a menu.
SOURCE: Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Posted on Dec 04, 2008
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
BillB-SA
  • 2761 Answers
SOURCE: we have lost manual for cobra microtalk walkie
I couldn't locate your specific model, but all of the Microtalk series radios seem to be basically the same as far as operations. Follow the link below to a manual that you can download/print -- it should work fine with your radios:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Bill B
Posted on Apr 18, 2010
micromatikal
  • 2777 Answers
SOURCE: have Cobra Micro Talk Walkie Talkies and have lost
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
Posted on Oct 12, 2010
cool78259
  • 228 Answers
SOURCE: I have the cobra micro
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Posted on Mar 10, 2011
Can't unlock my cobra walkie talkie model ctx 425c
Press and hold Mode/Lock button for 2-3 seconds until you get a beep. I think it is a double beep.
manual link: https://www.manualslib.com/manual/223471/Cobra-Microtalk-Cxt425.html
Apr 17, 2017 | Cobra Radio Communications
Loud crackling noise
The monitor function is turned on, on the unit that is noisy.
The manual describes the procedure for setting the monitor function the manual is available here.
https://www.cobra.com/support/product-manuals
May 11, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
How do i make my audiovox walkie talkie stop making a beep noise
In the "settings" there should be an option to turn off "beeps" or "tones" or "notifications", something to that effect.
Feb 16, 2014 | Radio Communications
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
What if your walkie talkie antena is chewed on and makes a buzzing sound
If the antenna is exposed that radio will get inductance, normally most walkie talkie antennas are
composed of a coil of bare wire, a shield around the wire to keep out inductance or noise, and
the outer layer to keep it together and protected. if the metal is exposed you can cover the area
with a piece of aluminum foil and wrap it with black tape or electrical rubber tape sold at most
hardware stores or an electrical supplier. or you can go and by another antenna. good luck!
Feb 23, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Jul 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Charging Problem
You can ask the seller you bought the walkie talkie from.
Sorry, I don't speak English very well.
Dec 25, 2008 | Cobra Radio Communications
Cobra Electronics CXT85  Two Way Radio Logo
251 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
