Question about LG Electronics M2262D 22" LCD Monitor
What are the best picture settings on LG M2262D TV for the best xbox 360 experience?
2 Suggested Answers
damnor01
  • 1179 Answers
SOURCE: LG M2262D, HDMI input bad quality?
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya!
Is this only on the HDMI connection?
This particular monitor supports another digital input called DVI, a white connector. Connect your monitor to your computer via the DVI connector see if this changes the state of the problem. Also try the VGA connection, however you wouldn't want to run this LCD on an Anolog connection for everyday use.
Also do the following:
Right click your desktop and select properties.
Click the Settings tab and ensure that the colour quality (found to the right of the resolution slider bar) is set to (Highest 32Bit)
If you find that your monitor works well on the DVI connection then one could say that the HDMI cable is either of bad quality or faulty. Installing the latest available drivers from the AMD website is a good idea, be sure to get the drivers for your version of the windows operating system. (32Bit or 64Bit)
Please be sure to rate this session.
Take care!
Posted on Nov 18, 2011
Lg tv m2262d
Hello!
If this TV is a Smart TV, connect it to your home internet connection and use the TV's system settings.
Hope this helps!
Oct 28, 2013 | Computers & Internet
I play my xbox 360 alot on my panasonic viera tc-p42c2 and just wanted to know what i should set my picture settings on that will be the best for the tv without getting a burn in image?
all lcd/plasma tv will suffer from burn image if you leave the xbox 360 on pause for hours at a time just playing game shouldnt leave an image on the screen as the picture is changing all the time the only way around this is an old style tv(tube style)
John
Feb 25, 2011 | Televison & Video
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
Need a manual for M2262D TV
User Manual for LG M2262D TV is available at LG Official Site. Click here and select 'Manuals & Documents'and download the required file.
CreativeTECH
Jan 10, 2011 | LG 22" FLATRON LCD Monitor
I have a iol tv and i dont no how to fix the picture so it looks right with my xbox
when on your xbox go to settings--------display-------------and in their check different settings until it looks ok now if the colour is wrong you might want to try changing your tv settings like gamma brightness etc... by going into menu on your tv best bet would be click menu on the remote
Mar 30, 2010 | Video Game Consoles & Games
We have sound but no picture on the xbox 360
The first thing to try is to remove the external hard-drive from your Xbox and see if the picture comes back. If that doesn't work you may have the video resolution of the Xbox set too high for your TV to display. Try reducing the Xbox resolution and see if you can get a picture. There is a switch at the end of the cable where it plugs into the Xbox that says TV and HDTV. Try setting it to TV. If you know someone with another Xbox 360 that you can borrow you can use it to debug your problem. If their Xbox works on your TV try swapping out the cables. You can see if your Xbox works with their cables and if their Xbox works with your cables. You should be able to narrow your problem down to either the Xbox, the cables, or the TV setup.
Jun 06, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
HOOKING UP XBOX 360 TO HDTV
You have to use the regular red and white cords(not the yellow) and u have to use all 3 hd cords. If ur tv doesnt have a place to put the cords in, then it isnt HD. Also on the plug connecting to the 360, there is a switch that has HD and regular, switch it to HD. hope this helped.
Feb 19, 2009 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
LG Electronics M2262D 22" LCD Monitor Logo
221 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
