Question about Panasonic DVD-LA95 Portable DVD Player
Flashing red light Panasonic portable DVD-LA95
I have a Panasonic portable DVD-LA95 and I can't get it to do anything. It just has a red flashing light where the "power" light is (next to the "charge" light). Any suggestions??
Thanks in advance for your help.
  • stanford115 Mar 19, 2009
    Mine started flashing red yesterday also. I'm assuming either the unit is dead or the power cord is dead (hoping it's the latter). Has anyone else had this problem? Is it fixable?
    Problem Solver:
  • 11 Answers
Check the microswith near the hinge . its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle. this happened tome and i was on the verge of binning it. when i looked at the manual and it says power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at choonzy@googlemail.com
good luck
choonzy
Posted on Feb 07, 2010
Panasonic dvd-la95 is region locked What do i do?
Hi, Unfortunately there's no way to unlock the DVD player, you have to buy one that isn't region locked.
Jul 19, 2011 | Panasonic DVD-LA95 Portable DVD Player
I have just bought a Panasonic DVD-LA95 but did not realise that it is Region 1 only. I need to change it to region 2 to be able to use it here. Can you help please.
you need to check that it supports pal output, if its a european unit (check the manual and player bottom for the ce mark) then it will play pal discs and will need reverting to the multiregion upgrade ( a disc and a few button presses about £20 online)) if its an american unit then it wont play pal discs even if you do manage to multiregion it.
Jun 25, 2009 | Panasonic DVD-LA95 Portable DVD Player
Stopped working while running.
flashing power light ??
thought you had to turn them off to charge it.
Jun 02, 2009 | Panasonic DVD-LA95 Portable DVD Player
Panasonic LA95 Portable DVD
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
Mar 11, 2009 | Panasonic DVD-LA95 Portable DVD Player
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
PANASONIC PORTABLE DVD PLAYER ERROR CODE 3. MODEL NUMBER LS5
This could be the laser going or a dirty track. I suggest that you first clean the laser gently. If this doesn't work you must take the player apart and clean the track that the laser moves on along with everything around it (keeping in mind that the laser is fragile).
Dec 03, 2007 | Panasonic DVD-LA95 Portable DVD Player
Screen very dark
hi sir you got a burnt fluriecent or a deffect transistor driver to it refer to qualified person to re change , but this is the fault sharply cost i2 20$ please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Panasonic DVD-LA95 Portable DVD Player
Panasonic LA95
You bought it on Ebay ! ! Why did the seller move it on...
I suspect that the decoder is getting 'hot' - same principle as the processor on your PC.
If you are able - I would suggest opeing the unit up (so that the main board is visible) but still able to power up.
Obtain a hair dryer that has a 'cool' blow on it. Start your unit up, while blowing with cool air - this will identify if this is thermal related...
Sep 07, 2006 | Panasonic DVD-LA95 Portable DVD Player
Panasonic DVD-LA95 Portable DVD Player Logo
403 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
