Question about Philips DVDR985 DVD Recorder
Phillips dvdr 1000
Hi i have a been given a phillips dvdr 1000 off a friend who said that one day it worked and the next it never.Is there a reset button to put it back to factory setting because he lives in the uk and i live in france so the setting will be different.The message i get when i turn it on is TURN ON TV and i cant get anything to work on it hope someone can help me Thankyou
  • 476 Answers
SOURCE: philips dvdr880
The DVDR880 displays "IS TV ON?" when it is in factory mode. You need to switch the TV to the DVDR input, as the on-screen instructions will tell you how to proceed.
Download the manual here:
https://www.p4c.philips.com/files/d/dvdr880_051/dvdr880_051_dfu_eng.pdf
Posted on Jun 28, 2008
SOURCE: i put my dvdr phillips recorder on progresive scan no picture
You will have to reset the DVD player in order to undo the progressive scan option. Since you cannot see a menu to do so...
1. Unplug the dvd player from the outlet
2. Press and hold down the STANDBY-ON m button on the front of the Recorder while reconnecting to the power outlet.
3.Release STANDBY-ON m when '  ' appears in the display. All the information stored in the memory (programs, time, TIMER) will be reset (cleared).
Hope this helps with your problem, thank you for stopping by Fixya! Please leave a positive rating if this solution works for you.
Posted on Mar 15, 2009
SpideRaY
  • 687 Answers
SOURCE: I have a Philips DVDR 3380. Will not turn on
Sounds like the power supply is dead check the secondary coil voltage.
240V AC Primary and 12VDC on the Secondary powering the motherboard
Posted on Jan 11, 2010
sandie3796
  • 132 Answers
SOURCE: How can I reset a Philips dvdr 3505 to it's
Press setup on your remote. Use up or down button to select( general settings ) press ok. Use the up or down buttons to ( reset all ) then press ok. Use the up or down button to ( yes ) press ok Use the up or down buttons again to select (yes) press ok. That should do it. If this works give me a vote please.Good luck.
Posted on Mar 03, 2010
Testimonial: "Yep that did help/work :-) thank you for such a fast response to a very frustrating problem. :-)"
BElectric
  • 1140 Answers
SOURCE: I bought some DVDs at amazon.com, but I live
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Posted on Jan 28, 2011
Phillips instruction manual
I want to record pictures from my camcorder to a dvd using my philips dvdr 1000/051.When i press record it's saying no disc.What can ido ?
Jan 12, 2014 | Computers & Internet
Yamaha wont start
Hi Denver, and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
1997 Yamaha Motorcycle Service Repair Manuals
Dec 20, 2011 | 1997 Yamaha YZF Thunder ace 1000 R
My Technika DVDr 2005 drawer will not open and has a DVD in place - how can I retrieve the DVD?
turn it off then unplug the dvdr then after a while plug it again and turn on, now press the play button after a while press the stop button then next is the eject button. if still the tray won't eject unplug the dvdr use a philip screw driver unscrew to open the cover. look for the plastic motor gear then manually turn it with your finger to eject the tray now you can get your dvd. place back the cover and plug the unit and then turn on to check if its working again and eject the tray. thanks i hope it will help you good luck.
Jun 13, 2011 | Televison & Video
My m.p.3 phillips gogear vibe now says :no space to build database,please connect to p.c. and create 100 mb free space,then turns off,please tell me what to do to get this to work again?
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird. Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair:
Launch Songbird and then connect your player to your computer. Select "Repair" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
Hope this works.
Feb 21, 2011 | Philips GoGear ViBE Digital Media Player
Okay, so I've got a fx-7400G PLUS. My stupid friend put the contrast to light and turn it off. The calculator stop working. What can I do to make it work again? Thanks in advance.
Reset the calculator. On the back of the calculator there is a reset button (Above battery compartment and to the left. Use a thin pointed object to push it. The calculator will ask for confirmation to reset all memory back to default. Press [F1] to accept.
And next time avoid hanging out with stupid people, and don't lend them your calculator. Didn't you know that stupidity is contagious?
Hope that helps.
Thank you using FixYa and for rating this solution.
Dec 03, 2009 | Casio FX-7400G Plus Calculator
I put my dvdr phillips recorder on progresive scan no picture
Mar 15, 2009 | Philips DVDR615 DVD Player
Philips dvdr880
Jun 28, 2008 | Philips DVDR80 DVD Recorder
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
Philips DVDR985 DVD Recorder Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
