Question about Whirlpool 20 cu. ft. / 566 liter Upright Freezer EV201MWH
Freezes up in the bottom of 16.7 upright freezer (whirlpool) won't drain
Serviceman was sent out and said a fix was to run a copper wire from the heater down the drain line
huuum
  • 750 Answers
SOURCE: freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Posted on Jan 31, 2009
mgprice
  • 744 Answers
SOURCE: Ice in bottom of upright freezer -- problem with tube position?
Hello, get a short piece of electrical wire and strip the insulation off. put a bend in one end and then hang it over the heater directly above the drain making sure the wire runs into the drain about an inch. the heat from the heater will make sure the drain stays clear. Hope this helps. Mike
Posted on Nov 19, 2009
  • 122 Answers
SOURCE: I have a Whirlpool Model EV 200N Upright Freezer
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Posted on Aug 28, 2010
kel1guy2002
  • 3740 Answers
SOURCE: fan on freezer won't com on but freezes food on
Hi and welcome to FixYa, I am Kelly.
There are 12 midelos that fall under the model number you passed. I will cite EV171NYMQ05 as a reference model number via this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769
The freezer fan should be on anytime the compressor is on. If there is an ice block built up on the evaporator coils it can lock the fan blade in place via the ice build up. Additionally... if the fan motor bearings are dry or coated with sludge this too can prevent the fan motor from operating. The fan motor is item 3 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28174432#d28174432
Detail views:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-motor-evap-item-number-ap4539455.aspx
To check the can motor all that is required is a simple continuity check across the 2 connector wires. You should read under 480 ohms.
If you discover that the fan blades are encased in ice... do a manual defrost: (be ready to tend to a water mess)
1. By first unplugging the unit and then removing the freezer contents.
2. Direct an external fan into the freezer compartment for just over 2 hours.
3. Make sure the compartement drain funnel is clear of obstructions. Item 11 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28158051#d28158051
After the 2 hour manual defrost period plug in the unit and test to see if the fan motor is running.
If it is running you may have an automatic defrost problem causing the ice build up. On a freezer the ice build up will start again if there is an automatic defrost problem in 3 - 5 days. Until the automatic defrost problem is corrected you will end up doing the manual defrost routine described above everytime you have improper cooling problems.
Components that can cause the automatic defrosting problems are
1. The defrost timer item 7 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28257341#d28257341 Because it is not cycling or stuck in one position.
2. The defrost bi-metal thermostat item 9 above link (stuck closed)
3. The defrost heating element item 5 above link. (open)
And of course internal wiring....
Check the fan motor for continuity... if you attempt to lubricate it which is very difficult on this fan motor make sure you use paraffin based "Turbine oil" and not a regular household or automotive oil. Using any other oil will cause the fan to stop working in as little as 30 days.
Thanks for choosing FixYa,
Kelly
Posted on Jul 08, 2011
  • 550 Answers
SOURCE: I have a whirlpool upright refrig.It stop making ice, then the water came running out through the refrig. and onto the floor.Now it freezes the water but it seems to be stuuc and won't make ice.Wh
the ice maker is not cutting off clean inlet valve shut off
Posted on Mar 22, 2012
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Freezer will not shut off some things frozen, bread and ice cream soft
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Same as post in Dec 09, I have water freezing at the bottom of my frostfree upright freezer (whirlpool).
Could be the drain is blocked, Otherwise the water would drain away and evaporate from the compressor unit.
Mar 27, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Nov 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
My upright freezer has a small amount of water inside that freezes, creating an ice slide in bottom.
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
Nov 06, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Freezer drain freezes, and constant clicking noise
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezing water line
Yes this freezer is built by woods corp. They had a myriad of drain icing problems. There is a kit to resolve this although sometimes it doesnt always work make sure that the plastic liner in the drain trough isnt cracked or it will let water in the liner, icing the drain. Seal any cracks with epoxy. Try running a piece of 14 guage copper wire strand (no insulation) from def heater and extend into drain hole. This will help it drain. All this is axcessed though back cover in freezer.
Oct 05, 2007 | Freezers
Freezers Logo
21 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
