Question about Falcon 1300 Dual Fuel (Electric and Gas) Kitchen Range
Small flame on hob
Hi the last propane canister ran out have connected spare and turned on gas but very small flame on hob turn on second hob ring and first goes out, have had major frost for last 4 days so have checked line as runs from outside......
Many thanks
D
    New Friend:
  • 47 Answers
You need to check the conecion to the gas bottle
make sure there is nothing bocing the conecion
like a twisted rubber seal ok
hopfully this is the anser yuo need
from lee
Posted on Jan 03, 2009
Fridge worked fine on gas last night but won't today.. Gas is at cook top
Gas refrigerators work off a small flame. That flame heats a part some call a thermocouple. Over time that part goes bad. Also Propane produces a carbon like soot. It sometimes blocks the small hole the gas flows through. May just need cleaned near the flame area.
May 20, 2015 | Refrigerators
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
I have full propane, yet a low flame?
he new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 29, 2010 | Thermos Stainless Steel Gas Grill
How can a Smeg gas hob be made safe when the flame goes out or it is accidentally turned on when cleaning the top.
The device that turns off the gas supply when the flame goes out, is called a thermocouple. If your cooktop model was not fitted with this device, you will need to turn off power at power point or fit a gas isolation ****.(Local gas and power laws)
Mar 22, 2010 | Cooktops
The flame on my Ikea DATID Hob is huge and has a lot of yellow flame. It makes my pots black, and is difficult to regulate because the flame is so big.
Hi, it really sounds like your cooktop is not set up for your type of gas. More than likely, it is set up for Natural gas and you are using Propane. You need to convert to LP using the kit. The only thing you have to change is the orifices.
Jan 18, 2010 | Cooktops
I have a goodman GMNT gas furnace Propane it lights off I have a blue flame for about 3 seconds I hear a click on the circuit board and the flame goes out this is doing it constantly. could you please help...
Hi!!! If the flame turns on then off and on then you should change your flame sensor on the gas furnace..YEs flame sensor is shorted..The flame sensor is located by the valve burners it has one wire and is white..Good luck..
Jan 03, 2009 | Heating & Cooling
Had a new gas hob installed but two of the gas burners only have a very low flame even when turned to high. One of the others has yellow flame tips even on low and is leaving marks on the bottom of the...
propane or natural gas? if it was converted inproperly it will leave soot on your pans. also you will see flames when you bake with it or broil.
Nov 01, 2008 | Kitchen Ranges
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Falcon 1300 Dual Fuel (Electric and Gas) Kitchen Range Logo
252 people viewed this question
Top Falcon Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Falcon Kitchen Range Expert? Answer questions, earn points and help others
