Question about Kenmore Elite HE4 Electric Dryer
Dryer just quit.. no buttons lit
I went to dry a load of clothes, the drum light was on I loaded it up pressed the button and - nothing. No buttons worked tried unplugging and plugging. Turned to the internet, someone said to push multiple random buttons at once.. I did and it worked, but now it is an everytime thing, and it seems to be getting more fickle about wanting to start. I paid big bucks for this thing that I thought would last me more than 2 years. Any clues what this problem might be?
  • 3 more comments
  • Valerie Sokol Jun 01, 2007
    Thank you for your suggestion. I will give it a try!
  • Valerie Sokol Jun 10, 2007
    I had Sears come on the chance that my dryer problem still might be covered under warranty for the SENSOR SMART electronic control board, but I was shocked as heck when the technician said it could be one or two things one is the central electronic (1 CNTRL-ELE) for $215.31 and/or 1 Sub central electronic (1 SUB CNTRL-EL) for $525.79 for a possible grand total of $648.96 after taxes. This is for parts only not labor. I told him to forget it, and how dissapointing that such an expensive dryer does not even last 2 years. It is not even paid for yet. Does anyone know the part #'s for these parts? I just want to check and see if they really cost that much thru a part suppy place. I will try to repair it myself if they cost less. Kenmore Elite HE electric dryer model # 110.85862400
  • bp6052 Dec 30, 2007
    My HE-4T gas dryer just quit...no lites except interior lite. It is less
    than 2 years old. My last Sears dryer lasted 20 years and still worked
    when I gave it away, and now I am out of warranty with an expensive
    repair on a new new $1000+ unit?
  • Resigned Mar 21, 2008
    Our dryer just quit. Then it started working and would continually beep during all of the cycles. Then it would quit again. We have been limping along for approximately 5 months. Now it definitely seems dead. It is definitely outside of the warranty period but certainly less than 2 1/2 years old.
  • Anonymous Feb 25, 2009
    I Have de same problem il faut les poursuivre envoit leur une lettre de mise en demeure et ils n'auront pas le choix.
    good luck
I checked everything on mine. Open the door and the light came on but nothing lit up on the control panel. I was able to track it down to the transformer being bad on the 115 volt side. I desoldered it and replaced it with another matching transformer and sure enough it works like new. You can run an ohm test on the terminals it should have 3 sets of two that will OHM out if working correctly. The transformer is ELYTONE EPS-4-24-W here is a PDF http://www.elytone.com.tw/pdf/EPS.pdf. Good luck all!
Posted on Oct 04, 2012
  • 3 Answers
Front Panel lights not working? Dryer inside light does work? I fixed this twice already on my dryer. Please read this whole explanation I live in New Orleans where the humidity is very high. I have a laundry room where my Washer and Dryer reside. Kenmore HE4T. I noticed that when I shut the laundry room door, my central A/C pulls hot air from outside the house via the dryer exhaust duct. This causes moisture to build on the inside of the dryer and especially the front control panel. Did you ever see moisture on your dryer?s door even when there were no clothes in it? The moisture collects on the Silicon board that controls the dyers function and basically causes a short. This is what I do to fix it. You will need a ¼ nut driver or socket. 1. Confirm that you have power to the dryer <- is the inside dryer light on when you open the door. YES- keep reading.. NO ? find the circuit breaker and reset it. 2. UNPUG THE DRYER! ! ! ! ! ! ! ! 3. Find the 3 screws in the back of the dryer that hold the dryer lid on. Unscrew them and slid the lid back and lift off. Is there moisture on the inside of the lid? 4. Find the 2 screws that hold down the front control panel. They should be silver and will be on top. Do not remove the inside gold screws. 5. Find the 3 screws that hold down the power control panel on the top left side of the dryer. Probably has a high voltage warning sticker on it. 6. Lift the power control panel (sheet metal) part and move it to the right so it lays on the dyers drum. There are some wires attached to it and unless you are a very handy person, I wouldn?t remove them. 7. Lift the front control panel straight up until it comes out of the dryer. There should be some wires that attach this piece to the power control panel. If you are handy, you can remove these 2 clip-on wires from the power control panel by squeezing the black connector locking clip and releasing it from the panel. 8. If you flip the control panel around you may notice moisture on the green silicon chips. Get a hairdryer and take your time to dry them. 9. Dry all components of the dryer with a hairdryer. 10. Put everything back together except for the lid and all the screws. Remember that the front control panel slides down first and then the power control panel sits on top second. Plug the dryer in and see if you get lights, but don?t start the dryer. Unplug the dryer and replace all the screws and the lid. The problem is that once the dryer gets wet from the moisture, it never dries enough for it to start working again. This is a bad design from Sears/Whirlpool. I learn my lesson that just because its more expensive doesn?t make it more better. I now keep my dryer and washer door open all the time even when there are no clothes in it. This lets the moisture escape into the house rather than collect in the dryer. I hope this helps at least one person. Thanks Jason Kennedy from New Orleans
Posted on Aug 14, 2007
  • Halogengirl Sep 24, 2010
    Is there a special way to do this without having the interior light stay on?
We had the same problem. None of the buttons would light up except the control lock button, and the door light continued to work. Humidity building up on inside door face.
Had an extended warranty from Sears.
The dryer didn't work for 3 days... then today (when the repair man comes, it starts working again).
He diagnosed it as a faulty console. Has to replace the console - part # SUB CNTRL-EL part $344.08
Posted on Sep 24, 2010
    Someone above mentioned leaving the dryer door open to prevent moisture buildup. Is there a special way to do this without having the interior light come on?
    Oh... someone above asked about part numbers:
    SUB CNTRL-EL part number on my ticket is: 26 110 280100 1
    I think the most important portion is the 280100 cause that's what the technician referred to the part as.
Jason Kennedy/New Orleans solution worked up here in Colorado. I followed his procedure and used a hair dryer to get it working again. There was a layer of lint dust on the PCB's maybe this had something to do with it. Unfortunately the fix was only temporary, however, and now the dryer is dead again.
I had to go through the dreaded Sears "1-800-4My-Home" service line and there will be a service guy coming in 5 days from now. Getting in touch with them was an experience unto itself and maybe the subject of separate posting on another site.
Posted on Dec 31, 2007
Had this problem....ordered front panel from Whirlpool ($269). Showed up 20 days later and replaced myself (easy). Fixed!!
Posted on Nov 08, 2007
I am having exactly the same problem however the only buton that works is The panel lock, if you keep it pressed for a few seconds it will beep and the led will light up. Otherwise nothing works. I checked the Front control panel switches according to the Service sheets, seems fine, I changed the main control board, same thing. I'm puzzled. Please post how you fixed your problem. Thank you.
Posted on Aug 30, 2007
I had to replace the whole front control panel, it was easy to do , expensive- but not nearly the price that Sears wanted to charge. I still would not recommend anything from Sears.
Posted on Aug 15, 2007
Sear's says it is not the part that is covered under the 2 year warranty. That is the only reason I called Sear's in the first place, I was hoping that the part that went wrong was under the 2 year warranty... no such luck. I'm going to replace one of the parts myself. It is on backorder when I try it I will follow up. I appreciate everyones input.
Posted on Jun 12, 2007
  • joe anderson Jul 10, 2012
    this is jta from chicago, it's been hot as hell here so I also had humidity building up inside my dryer (hot humid air coming in the exhaust). my unit was unpluged & partially disassemble while looking for the defective part, and searching the internet for answers. Put the unit back together and now that it's dry it works fine. I just leave the door open and all is well.
    President:
  • 878 Answers
Aebles, in your post, I told him to forget it, and how dissapointing that such an expensive dryer does not even last 2 years, this smart sensor board is warranteed for 2 years, part only. If it's under 2 years have them replace it. I had one once with the same problem and believe it or not it turned out to be the thermal fuse. Usually, if these fail, they're done.This one tested good. It drove me crazy. I changed out that fuse and never got that call back. Catriver.
Posted on Jun 10, 2007
  • 883 Answers
There may be a micro-controller chip on board that has had its boot loader program scrambled. open the unit and look on board for the word "reset" and it may be next to a board mounted switch or connector pins
Posted on May 29, 2007
SOURCE:
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
I have the LG Model# DLE1101W dryer. The dryer will power up but when I go to start the dryer after I put a second load in, I get a series of dinging sounds when pressing the start button and the drye
Id like to see if I could help you so you will have to use more definitive terms, "Start" I'm guessing that you mean that the drum doesn't turn? (the lights come on and you push the start button and the drum does not turn) If that's the case I would start with the door switch, Best to start with the most obvious first. Try jumping it to over ride wait your response
Sep 17, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
Kenmore Dryer Model No. 110.64632300
If it is 6 years of age or older and have a lot of use in the past you will be better off replacing it. The cost to repair it will outweigh its age and cost to repair
May 20, 2010 | Magic Chef CYE4000AWW Electric Dryer
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Control lock stays on and nothing else works on the panel. No other lights, no other controls. Disconnected power overnite but nothing changed.
The sound button is the button that you wish the sound to go on when the load is finished drying. Thanks for the advice, I was worried I just bought them and already broken.
Nov 17, 2007 | Whirlpool GEW9250P Electric Dryer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
1,226 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
