I need user manual for singer projector caramate 3300
Singer educational division for projectors
Beni S-P
  • 1006 Answers
SOURCE: canon imagerunner 3300 user manual
Here you go:
Download
Rate me as FIXYA please?
Posted on Dec 27, 2007
fredcause
  • 51 Answers
SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Posted on Dec 08, 2008
  • 3 Answers
SOURCE: infocus projector x3 user manual
I had the same issue too. Dream Vision also makes the DL500 under different brand names.
Try the Kodak DP850 manual.
http://www.kodak.com/global/plugins/acrobat/en/service/digProj/dp850/manual/eng.pdf
Posted on Jan 03, 2009
welcomejee
  • 10594 Answers
SOURCE: DO NOT HAVE A USER MANUAL- AHARP XR-11XC MULTIMEDIA DLP
You can download user manual of Sharp XR-11XC from HERE for free as website will ask you any of your email address only.
User manual has all info about this unit.
Posted on Feb 12, 2009
suraj4us
  • 61 Answers
SOURCE: User Manual
Go through this below weblink..
http://www.theusermanualsite.com/manuals/mfg/3m/mp8670.html
read the instructions and go through it if you are interested.
Regards,
Raj
Posted on Feb 18, 2009
I just got a used Telex Caramate 4000 slide projector but no manual. Who has one I can buy?
sadly when buying used items getting a manual would be the first thing I would ask about from the seller .. you can try searching thru Google and hope for the best
Jun 07, 2016 | Office Equipment & Supplies
How can I delete a used projector's previous owner's password/settings?
unfortunately for you - mitsubishi abandoned they excellent projection division and most of they electronics division in 2013. you should have this procedure (return to factory settings) in your manual. i do not know this particular model but on some of them you need to switch off, held selection button and switch power on, holding the select for about 20 sec. check combination of the buttons and one of them will work.
if you have disk (some of them were supplied with cd) there should be little program on it which will allow you to control the projector from computer, it should have reset function somewhere on it.
try this site - but they are notorious for looooooong waiting time for answer:
http://www.mitsubishielectric.com.au/163.htm
hope aty least one of them will work for you - do not forget to vote...
Jan 11, 2015 | Mitsubishi XL8U Multimedia Projector
I need to reset the lamp life timer on my projector, but it requires a password. We never set a password. Is there any way around this?
From the manual: " User name and password are not set in the factory " . Don't enter anything.
Manual for the projector here:
http://www.projector-manual.com/manuals/eiki/EIKI_EIP-4500_DLP.pdf
Jul 22, 2014 | Eiki EIP-4500 DLP Projector Multimedia...
Want to transfer slide pictures from a Telex Caramate 4000 to a laptop. Is it possible to do this?
you need telecine transfer facility take it to duplication house they might help ypu
Dec 21, 2013 | Telex Caramate 4000 Used Audio Visual
Projector turns itself off and on
Caramates have a Thermal Breaker built into their electrical circuits, which will "open" if the internal temperature gets too high for safety. When the internal temperature drops to an acceptable level, the breaker "re-sets" and the projector will come back on. You will need to check for any obstructions to air flow first. Next, make sure the exhaust fan is running at the proper speed. Once those items are checked, if the problem still exists, you will need to locate a circuit diagram and the appropriate thermal breaker for replacement. Good Luck!! Jim
Oct 27, 2013 | Kodak Office Equipment & Supplies
I have an OLD telex projector. Looks like a box with a tv screen on one side and carousel on top. have no idea how to use it. maybe bulb needs replacing
Telex called those "CaraMate XXXX" (XXXX usually relating to model number ). The old ones projected on the internal screen. Newer models could project both on the internal screen and (by sliding a door on the top panel) on a projection screen for larger audiences.
If it needs a lamp, check with: www.bulbman.com But you may have to search - - it's been a long time since they were manufactured!
Good Luck !!
Jun 21, 2011 | Telex Office Equipment & Supplies
I have an old Kodak Caromate 3300 slide projector. Can I get a manual for this? I cant get it working properly, ie carousel will not move forward and slide cannot be viewed.
Is it a Kodak AudioViewer or a Caramate 3300?? hard to tell from the problem description.
If it is a Kodak branded unit, I know Kodak doesn't have the manuals any more, so my advice is to contact a factory-trained service dealer to see if they still have a service manual!
If it is Caramate branded, I'm really not sure where to send you. There were subtle design differences between the 2 brands!!
Good Luck !!
Feb 04, 2011 | Kodak AV210P 80 Slides Rotary Carousel...
ELP 3300 lamp problem?
probably. try to check the number of light hours( you can check the manual on how to view it) usually 10000 hours could mean that you need to replace the bulb. also check the physical appearance of the bulb, if it has cracks on the ceramic at the back, then you need to replace it.
Jan 29, 2009 | Epson (1023661) Projector Lamp for...
Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
87 people viewed this question
jasbo
jasbo
