Question about Whirlpool Cabrio Washing Machines
Need to remove tub from Whirlpool Cabrio WTW5600XW0
Not sure if there are locking clips in front. How do I open the lid to get to the tub?
  • 1028 Answers
SOURCE: The Lid Lock will not
bad lid lock most likly cause..clips under edge of top release top switch mounts to front edge of top and wires runs to control under console
Posted on Apr 27, 2008
aborcass
  • 2651 Answers
SOURCE: sock stuck in outer tub whirlpool cabrio
youll need to "pop" the main top.. then unsnap the outer ring that cvers the outer tub. if you look at the center of "agitator/ or bump plate depending on model" theres a small cap that will come of fand reveal a 7/16 screw remove the screw, and then oyull be able to lift the entire inner basket right out to retrieve any debris.
Posted on Feb 14, 2009
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
  • 24 Answers
SOURCE: 5 month old Whirlpool Cabrio washer has moldy
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
Posted on May 29, 2010
  • 1382 Answers
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Posted on Jul 28, 2010
Washer whirlpool cabrio wtw5600xw0 wll not start when I press the start button
You will need to replace the lid latch assembly. The control is not getting the proper response from the latch. Here is the part to order.
I also have a service manual available if you should need it.
Feb 14, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw5600xw0 will not spin
There is a spin sensor that is part of the shifter if this is wet it wont sense the spinning, hence wont spin, and if it is wet you mat need to replace the tub seal http://www.appliancepartspros.com/gearcase-motor-pump-parts-for-whirlpool-wtw5600xw0.html
May 29, 2012 | Whirlpool Cabrio Washing Machines
I had the power button off so no lights were lit. I also tried it in teh done mode. None of the buttons put it into self test.
My issue with spinning is it will not complete the spin cycle and the lid lock light flashes leaving water in the tub. If I out the machine on drin and spin it will remove most of the water
I also tried the soil level temp keydance to check the console self test and it would not go into that mode either.
Honda Parts.
May 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
The load finished on my whirlpool cabrio washer (topload) but the machine won't unlock the lid?
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
May 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio Model #WTW6200SW0 A F51 code keeps coming up. I would like to know what that means and what part i need to fix it. My husband does all the repairs on our appliances. Thank You.
well the code means that the tachometer or Rps sensor has detected a spinning problem but i would first push in the top clips on the right and left front corners about an inch in on the front and hinge back top lid remove top plastic cap ring of washer and check for stuck clothing between innertub and outer tub sometimes you will have to remove tub to get all clothes out remove center dome agitator center cap and remove 7/16 bolt pull agitator out the pull inner tub out then extract clothes be very carefull these stainless tubs are very sharp and will cut your hand like a cheese grader
Jan 24, 2011 | Whirlpool Washing Machines
How do I open the top of the washer to change out the lid lock part?
top/front of washer seperates by way of hidden clips. insert putty knife or butter knife between front seam of cabanet and top. about 2 inches from left side and 2 inches from right side push in and pull up on top. lid switch is located under top/front
Nov 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
May 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have change stuck is washer making noise when washing. How do I get it out
If this is a Whirlpool Cabrio, it has two pumps. One is the drain pump and the other is a recirc pump. In most cases, loose change an other items end up in one of these pumps. The following link explains how to access and check the pump(s) on the washer for obstructions.
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
If you have something stuck in the wash tub, you will need to remove the washplate in the center of the wash tub. Follow these steps:
1. Lift the washer top panel by locating the retaining clips in the seam along the front (about two inches in from each side). Use a putty knife to push in while lifting on the top panel to release.
NOTE: Its a good idea to tape the lid shut to prevent it from flying open when you lift the washer top.
2. Remove the wash tub ring. This is the plastic ring around the perimeter of the top of the wash tub. There are a series of release tabs around the tub that you can pry with a screwdriver.
NOTE: The washplate will not come out with the tub ring in place.
3. With the tub ring removed, pop the center post cap off the washplate. Locate the center nut and remove. Hold the washplate with one hand as you loosen to keep it from turning.
4. Lift the washplate out of the tub.
With the wash plate removed, you should easily be able to access anything stuck in the spin basket.
If you have any questions, or if this is NOT a Cabrio, please post back and let me know. I hope this helps you.
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Two dollar coin fell into a space between agitator and a drum.
you can pop of the agitaor ( held on by a 7/16 screw to the the inner tub will lift right out, it merely rests upon the spline, youll need to "pop" the main top first by "popping hte release clips. approximately 6 inches form either side between the main lid and the front panel are the clips, use a sturdy putty knife as these are tough to undo, the outer tub ring then simply unsnaps off and youll be able to remove the inner basket with no problem.
Nov 19, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
HOW DO I OPEN THE WHIRLPOOL CABRIO WASHER
control panel, board and valves are on top, remove three screws in rear of console, tilt forward and off. top panel with lid is clipped in front, use putty knife to press in two clips, just feel for them with knife in gap, lift at same time one tends to relatch while opening other. motor, hall sensor and drain pump located underneath tub, just lay down machine
Jun 03, 2008 | Whirlpool Washing Machines
Washing Machines Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal De
