Question about LG DLG2524 Gas Dryer
Cracked drum on LG Dryer model DLG2524W - LG DLG2524 Gas Dryer
  • 163 Answers
SOURCE: I just moved and my LG dryer does not heat up.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
MNTECH
  • 1543 Answers
SOURCE: Cracked Drum on LG Dryer Model #DLE2512W
If you are still looking for information on this:
No, there has not been any recall.
It is not a real common problem. I only see 1 or 2 a year, which is not many. (LE errors on washers are much more common, for example) The part number of the drum for a DLE2512W dryer is 3045EL1002D and lists for just over $100. You can find a service center to order the part from (in the US) at http://us.lgservice.com/index_b2c.jsp
I would rate the repair at about a 5 or 6 out of 10 on a scale of 1-10 in difficulty. (Basically, remove top, remove front control panel, remove front panel, remove front drum support, remove belt, drum comes out the front, reassemble.)
Posted on Jan 21, 2009
  • 5 Answers
I had a 2514 with a similar problem. Cracked drum. This is what I did to fix it. With the new drum. No noise at all.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
MNTECH
  • 1543 Answers
SOURCE: cracked drum on the DLE3777W model
The drum is a part number 3045EL1002F which will set you back at least $135. Still well worth the repair, especially if you can install it yourself. You have to remove the top by removing 3 screws in back and sliding top back about 2 inches and lifting off. Then, remove front panel. Remove 4 screws holding the front bulkhead. Remove belt from drum. Remove drum. First time might take a hour, second one you do will take about 15 minutes.
Now, don't rate me down because you don't like having to repair your dryer. I didn't manufacture it. I'm just giving you a bunch of free advise.
Posted on May 18, 2009
SOURCE: LG DRYER MODEL DLE3777 CRACKED DRUM,,CAN I JB
you need take out for weld it and pulish all weld.
Posted on Oct 06, 2009
There is a hole in the inside drum of the dryer
LG is responding to the complaints of cracked drums in their entire LG dryer line up by offering a replacement for the cracked drum part for free.
NOTE: This will only apply if you have an authorized LG servicer replace the drum for you. The labor is not covered so you will have to pay for the labor to have the drum replaced. You can call LG customer service at 1 800 243 0000 for more info.
Read more: http://appliancejunk.com/forums/index.php?topic=8308.0#ixzz28L6qVgMh
Oct 03, 2012 | Dryers
LG DLG2524W gas dryer with check filter light on. Dryer will work but no heat. Totally vacuumed filter and filter area out. Opened cap on bottom side of dryer and vacuumed that out but still same thing....
It sounds like the high limit switch has tripped. You will need to disassemble the dryer to get to the switch to reset it. LG recommends replacing the high limit switch.
Aug 05, 2011 | LG Dryers
How to re-install the LG DLG2524W Belt?
remove the top and front covers,then slightly lift the drum up and thread belt over and around the drum,then on the unit theres a drum belt routing diagram for the drum,motor,and the idler tensioner pulley
May 13, 2010 | LG DLG2524 Gas Dryer
Cracked drum on LG dryer
visit this online store I believe the price is $164 before shiping.Thanks for your interest in Fixya.http://www.appliancefactoryparts.com/search/partinfo.php?partsID=324980&modelsID=125623&typeName=applianceshvac
Sep 04, 2009 | Dryers
Dec 22, 2008 | LG DLE2512W Electric Dryer
Your ignitor (glow bar) got broken during the move. They are more fragile than your grandmother's fine china
Dec 16, 2008 | LG DLG9588 Dryer
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
LG DLG2524 Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
