Question about Sony Playstation 3 (PS3) Console
Download error (80710101FF) ps3
I cant download any demo games without an error code coming up
gabrielsimut
  • 97 Answers
SOURCE: Demo Mode Playstation 3
In security settings press and hold select + square + L1 and L2
than enter 1 of these following codes depending on your version number
1.5x code: 5202
1.6x code: 7568
1.7x code: 0506
1.8x code: 7712 or 7259
and the ps3 will be unlocked from demo mode!
but be aware that this will only be for a couple of minutes.
so make sure you have the latest firmware the not demo one but the ordinary from the playstation site on a removable storage media
something like a memory stick or flash drive
so you can update immediately after unlocking you ps3! only this way you can completely unlock your system
Posted on May 02, 2008
SOURCE: error 80029564
try deleting the demo/game and downloding it again but DO NOT DOWNLOAD IN BACKGROUND! i had he same issue and i just re-downloaded it and put telly on. when i came back, the game had installed and was working fine
Posted on Feb 01, 2009
  • 1044 Answers
SOURCE: PS3 wont play blue ray or PS3 game discs
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
Posted on Nov 28, 2009
RixsFixes
  • 2200 Answers
SOURCE: how do i fix a ps3 error code 8001050f ??
There is a major problem right across the board at this very moment with the PSN Network, whereby some consoles are not synching properly and causing problems like you describe.
For a full breakdown please see this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
Posted on Mar 01, 2010
ginko
  • 19396 Answers
SOURCE: my ps3 wont play any
Hi.
As far as I know there is no notice of a firmware update causing a PS3 not to read any BRD. At most, some of the older firmware update caused the PS not reading some BRD. I think that the advice of downgrading firmware was unfounded, as often happens here where there is no control on source credit.
If firmware is 3.5 or later, you do not do to do any update. This firmware versions support any BRD.
To check the version of system software, go to Settings(the icon with the toolbox) > (System Settings > [System Information]. The information is shown in the [System Software] field.
If your firmware is older, update the firmware to the latest release. I suggest to update the software using the PS3 internet connection rather than download from PC. If you use Internet download, ensure thatyou download the right firmware for your region. Here the page for US. You do not need to select region or software version if you use PS3 connection to perform the update.
To find the update for your region, type "Sony PS3 Software Updates" in Google box.
Althought some older firmware is available on the Internet, I suggest NOT downgrading the PS3 system software. This for three reasons.
1)Downgrading to versions before 3.5x (quite recent) will reduce PS3 capabilities, and some new game may not be played unless you update again through the game.
2)There is no mention about this problem getting solved by downgrading PS3 firmware. Not from techs posting on the Internet, nothing from Sony either. Only firmware mention is from uninformed users in forums, nobody mentioned the downgrade fixed the problem.
3)The PS3 will update again by itself if needed (eg. through a game).
The easiest way to update is to downloading the update on the PS3 itself. Go to Settings menu, and find System Update. Select to Update the PS3 via Internet. The PS3 will automatically check for updates. If an update is found the PS will start the update, the process will be almost automatic.
When download is complete press X button and start installing the update. After install is complete you will be asked to perform some more steps. Follow the on-screen instructions to complete the update.
To update from PC, use the link above, and click the Download Now button . Put the update on a flash memory card. Make a New Folder called PS3, inside PS3 make a folder called UPDATE (in all capitals). Store the Update file you downloaded and into the UPDATE folder. Use the USB memory on PS3 and perform the update selecting the file you downloaded.
This method can also be used to download and install older firmware.
Now....ABOUT YOUR PROBLEM.
Some older firmware version also caused the problem shortly after update, but that was back in 2008, with versions 2.3x. Problem was fixed updating firmware again in one week, rather than downgrading.
If problem occurred shortly after an update, do a new update, just in case.
The problem is indeed common, and rather than by firmware , it is usually caused by wrong power to laser beam. In some case by dirty lens . I suggest calling Sony, and insisting that you did not damage your PS3, sometimes Sony decides to carry the repair. If they do not carry the repair, the technicians usually replace the whole driver. DIYers may take apart the PS3 to clean the lens or to adjust the laser (this last is rather difficult, as it can't be done tweaking a single pot, like in Xbox).
Performing this last actions will invalidate warranty, and there is chance to damage the PS if you do not do things proper way. Do this only if you have no hope to repair the PS. Here how to do a basic lens cleaning.
Do a firmware UPDATE and CALL SONY as first step. If you can't get PS3 repaired try cleaning lens. If all that does not work, then the optical drive must be replaced.
Regards.
Ginko.
Posted on Jan 09, 2011
How was the msi on the 90's?
Go online to find experts that may guide you step by step.These menonline may show you how to fix your console just as an experienced repairmanwould fix it. Allthese errors can be fixed completely by you without the involvement of anyexternal agency. Disassembly 1.PS3 Disassembly 2. PS3 Controller Disassembly Fix Common Problems Fix to all update related problems 1. The Mystery of the Blinking PlayStation 3 2. The dirt on Blu-ray lens (and how to clean it) 3. PS3 Owners Report Blu-ray Problems After 1.5 Upgrade 4. PS3 Bluetooth Controller Issues 5. Playstation 3 HDMI Problem and Fix! 6. Display/Video Fixes 7. PS3 Error Codes (With related fix) 8. How to Change From HDMI > Composite Easier 9. PS3 3 Beep & Blinking Red Light Fix PS3 Modifications 1. PS3 3.5" SATA HDD Mod 2. Adding IR Remote Control to the Sony PS3 3. PS3 HDD Replacement Mini-Guide 4. USB Flash Memory, USB Hard Drive (External Use) Controller Modifications 1. PS3 Controller Light Mod 2. PS360: Microsoft Controller, Meet Sony Controller 3. PS3 Controller Light Mod 2 4. PS3 Controller Button Contacts, Add extra buttons to the PS3controller Other Modifications 1. Charging Station Headset Mod Blu-Ray 1. Decrypt Blu-Ray Movies with a PS3 WITHOUT keys 2. Blu-Ray Unique Volume Keys 3. Blu-Ray Media Links 4. Play BluRay movies without disk 5. Convert HD-DVD To Blu-ray (works On PS3), No Loss Of Quality Other Media/Video 1. Set up media servers for your PS3 2. Transfer files from PC to PS3 via WmP11/Nero (viaDLNA/MediaServers) 3. How to stream AVI files on PS3 via Tversity 4. Copy music/videos from your iPod to PS3 5. Getting your PS3 to recognize your External Hard Drive 6. How to create a PS3 HD-MPG from HD-TS (Best Result For Below 1.6FW) 7. How to install your game saves 8. Downloading PS3 Game Saves Audio 1. How to connect PS3 to PC speakers Networking 1. How to change from 'NAT type 3' to 'NAT type 2' 2. Make a Lag Switch 3. Who Needs SIMPLE DNS 4. Remote Play On-The-Go Playstation Network 1. PSN Game Sharing Instructions 2. How to download Japanese Demos/Create *** PSN account 3. Create Different Region PSN Accounts 4. View PS3 Store, Download Demos on your PC and install Demos To PS3 5. Play Online And Access Sony Store No Updating 6. View Playstation store on PC Firmware Modifications 1. PS3 Firmware Version Check Bypassed (Linux) 2. PS3 Firmware Version Check Bypassed (Windows) 3. Ettercap Windows 4. PS3 Demonstration Mode "Unlock" Code 5. Use SIMPLEDNS To Bypass The Firmware Check (Windows) 6. How to UPDATE your PS3 Linux 1. How to install Fedora Core 6 Linux for PS3 2. PS3 Linux - The void has been filled...Full install instructionsfor Fedora Core 5 3. PS3 Linux FAQ 4. GUI Kboot 5. Yellow Dog Linux Free Version 6. Yellow Dog Linux 5.0 Installation 7. Partitioning and readying your PS3 for Linux 8. Gentoo 9. Uninstalling Linux 10. Installing YDL+VLC+Mplayer+Snes9x 11. Installing Mplayer on PS3 12. Installing VLC player on PS3 13. Installing "Other OS" on PS3 14. How to get Wi-Fi to work with YDL 15. Set up a Linux UPnP media server w/PS3 support 16. Run Ubuntu Linux 7.04 (Feisty Fawn) on PS3 17. Ubuntu, Kubuntu, Xubuntu, and Edubuntu onto a PlayStation 3 18. Emulate WinXP in PS3 under Linux Downloads 1. Homebrew Loaders 2. Linux 3. Utilities 4. Firmware Updates 5. "Other OS" Bootable Homebrew 6. Drivers 7. Proof-Of-Concept Exploits 8. Game Saves PS2/PS1 on PS3 1. Do your PS2 games look too jaggy on the PS3? Here's a semi-fix... 2. PS3 SWAP to play PS2 and PSX Games! 3. How to play/install to play PS2 backups on PS3 Miscellaneous 1. PS3 Features 2. Finding RAM locations on resistance 3. PS3 Parental Controls How-to 5. PS3 BiOS Flash Diagram Rev 1.0 So,if you have experienced some of the errors in your console, it is not the endof your gaming days, you can fix it. There are many solutions out there if youare willing to do a little research. This guide most possibly willcontain the solution to the problem you have encountered.
Ps3 repair guide Goodluck, and happy gaming.
Feb 08, 2011 | MSI 1990 - 1996 for PlayStation 3
I want games free
Feb 08, 2011 | EA - Electronic Arts Need For Speed:...
I lost my biohazard4 game CD key.... Can u Post key to my email ID: balumahesh8055@gmail.com
Feb 05, 2011 | Capcom Resident Evil 5 for PlayStation 3
How do i fix a ps3 error code 8001050f ??
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Hey there, just bought a ps3 off a mate of mine. Everything works well, but cant change any settings as it keeps coming up "Not allowed to whilst in Demo mode. Also, just bought an adaptor for my memory...
Hold L1, R1, and select simultaneously when the security settings icon is selected in the XMB. Then it'll ask for you to input a code. 5-2-0-2, This will unlock it from demonstration mode.
If it's a PAL PS3, well sorry I dont know the code.
Dec 07, 2009 | Sony Playstation 3 (PS3) Console
An error occurs during ps3 download installation
The only thing you can do is to restore the PS3 to original, then download your upgrade again.
May 25, 2009 | Sony PlayStation® 3 (80GB) Console
Power Button
just install your ps3 demos on system use webbrowser on ps3 to download demos or store the ps3 canot be shut down by power button on system itself only from controller or turning back off then on hope this helps
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Error 80029564
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
