Question about Kyocera Office Equipment & Supplies
Printing envelopes on kyocera copystar 3050
Can one of the paper trays be used for envelopes?
SOURCE: Envelope printing
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem. Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
Posted on Jun 02, 2007
Rubec
  • 42 Answers
SOURCE: Can't print from the MP tray?
When you print labels or envelopes you need to select the correct tray from the print menu. (File print or ctrl P) or the printer will think the normal paper tray is being used.
You can force the printer to change the tray after the print has been sent by pressing the continue button on the printer, just make sure that the normal tray has no paper in it.
Posted on May 11, 2008
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
dnewcombe1
  • 1564 Answers
SOURCE: My HP LaserJet 3050 will not grab and feed paper
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
Posted on Sep 04, 2009
How do I get the pritner to pull paper from open tray if there is an envelope or special paper being used?
You need to set the correct paper in the bypass tray settings on the machine. Once that is input you will have to tell the printer that you would like to print on envelopes through the bypass tray. This is done through the printer preferences. Hope this helps!
Oct 07, 2014 | Kyocera Mita FS-4100DN Mono Laser Printer
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
Envelope printing error - envelope prints wrinkled from MP tray
sorry buddy but mfps wrinkle envelopes he have tried many things on many models they all wrinkle the best thing you can do is try to reduce the wrinkle we tuck the flap inside and that helps a little other than that sorry
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
PRINTING ENVELOPES FROM MASTER LIST IN WORD-HOW TO GET THEM TO FEED AUTOMATICALLY?
They wont, its a way to make sure that you have envelopes in the MP tray..
Alot of my customers ask the same thing, there is no way to change that.
Oct 14, 2009 | Kyocera Copystar CS-1820 Black and White...
I have a Kyocera Mita KM-4230 and I'm trying to print a #10 envelope and its asking me to use the MP tray. But it's not accepting the envelope, what do I do?
but the envelopes in the tray on the right side of the machine... open all other trays.... and attempt to print... it will ask for you to select the tray... in which case you select the mp tray... and print... now for a more permanent solution... call kyocera support and they will walk you through the proper procedures...
Oct 07, 2009 | Brother HL 5250DN Laser Printer
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
I need the paper tray (the one after printing for a Copystar cs-1435
You will have to call a CopyStar dealer or a Kyocera-Mita dealer to get that part.
Dec 09, 2008 | Copystar Office Equipment & Supplies
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
104 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
