Question about Water Heaters
Hi, got a Saunier Duval Isomax F28E where the domestic water pump stays on even when no water is demanded. It only goes off when the control panel selector is in the "heating only" position. Please help.
4 Suggested Answers
  • 3 Answers
SOURCE: How do I increase the water pressure on the saunier Duval boiler?
not enough infromations give more detail
Posted on Dec 09, 2009
aquaman987
  • 927 Answers
SOURCE: Hi, Got a Saunier Duval Thema
http://www.saunier-duval.co.uk/manuals/pdf/noncurrent_products/installation_ThemaF23e-SBF23e.pdf
Here are complete instructions for installation and service including purging air and refilling. One of the first suggestions is that service is to be referred to a competent technician.
Gary
Posted on Dec 18, 2010
  • 7 Answers
SOURCE: Hi, I have a Saunier Duval? Theilea twin 28e
You may want to check the Pressure Reducing Valve On the supply line to the building. Easiest way to check is get a guage that hooks up to your hose bib (usually found in the sprinkler section at your hardware store). If your pressure is getting above 80, you need a new PRV.
Posted on Feb 14, 2011
My boiler dosent come on i have no hot water but when i turn the heating on boiler works but still no hot water what should i do
Hot water is gravity fed through your pipes. When you turn the faucet on the water will flow through the pipes. If your hot water heater is natural gas driven relight the pilot. Same if oil fueled. If electrical, check fuse to see if it has blown or the circuit breaker has tripped. If either has tripped, replace it and if it blows again the heater has a serious failure, you might need to buy a new one. If pilot won't light on gas unit, try relighting after 5 minutes, could be a bad thermocouple.
Apr 03, 2015 | Water Water Heaters
Saunier Duval ISOFAST F35E on hot water only makes a noise like a motor bike that vibrates through the pipework, this does not happen when the central heating is on, any ideas as to the cause.
The water pipes (steel) are probably full of rust. The noise is air in the pipes.
Use the pressure relief valve to let air escape.
The risk is if the relief valve is old it may not shut off.
Also air will build up again
Nov 05, 2014 | Water Heaters
Can I get a manual for a saunier duval instaneous gas water heater?
Yes. Just go through the company you purchased it from for this manual.
Sep 09, 2014 | Water Heaters
Saunier duval parts
If you are talking about the damper flap on the flue pipe. You have to go to a heating supply and buy a new flue that is already attached to a section of new pipe and fit it together. I'm not sure if your flue is free flap type of arm driven. British gas is trying to make a buck off you . Call a regular boiler repair man if you don't feel comfortable doing it your self.. Mine came apart at the hinge. The pin came out..I replaced it with a wire brad (nail) and it works just fine.
Dec 12, 2017 | Water Heaters
Boiler pressure saunier duval
Appear to be corroded/plugged inlet valve. De-pressurize system and check inlet valves and line.
May 11, 2013 | Water Heaters
Low pressure Saunier Duval therma condens boiler
May need to replace valves (appear to be corroded and plugged with deposits) and install a water conditioner in the inlet line if you have hard water.
Feb 14, 2011 | Water Heaters
Hi, Got a Saunier Duval Thema F 23 E and need to repressurise it (currently at 0 bars). can you provide any help on how to do it? Thanks.
Gary
Dec 18, 2010 | Water Heaters
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
85 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
