Question about Vacuums
How to fix cyclone rake collector bag tear
Have a tear on the cyclone rake Xl collector bag can it be fixed?
2 Suggested Answers
grumpytoolgu
  • 69 Answers
SOURCE: my cyclone rake impeller dissintegrated... Nedd a new impeller...
Try calling the factory at :
Woodland Power Products, Inc.
72 Acton Street, West Haven, CT 06516
Tel. 888-531-7253
Fax 203-934-3405 Business Hours 8:30 - 5:00 PM M-F Eastern Time
Posted on Dec 13, 2011
My sa380 15 inch auto planer dumps the shavings out the bottom even with the 4inch dust collector running this just started Is there a ajustment Ican make to correct this problem
Although the way you worded the questions suggests a wood shop problem, it is listed under vacuum cleaners.
I will speak to the planer being a wood shop machine.
I'd start by checking the dust collector for suction.
If it draws strongly, then perhaps you need to design a "chute" to cause the chips to go to the collector.
Perhaps a "rake" would be in order to move the chips neared the collector.
A rake nothing more than a broomstick with a flat board fastened to the end.
God bless your efforts.
Sep 08, 2016 | Vacuums
How do I, get the outer bag off to replace it.
Debby,
Do you have a bag dock that holds your paper bags? If you do, squeeze the bottom of the part that goes around the bag opening so that you can remove the hinged part and then you can spread the first part & take it off & then remove the bag. If you do not have a bag dock, there is a "U" shaped metal clip that goes over the opening on the connector assembly. Remove that clip & that will allow you to remove your bag. Hope this Helps!
Jan 19, 2015 | Oreck XL Ultra Bagged Upright Vacuum
How to fix oreck xl vacuum
Really depends on what you need to repair.
We offer many of the parts needed here:
Oreck vacuum parts
800-775-6586
GoodVac com
Jul 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
My cyclone rake impeller dissintegrated... Nedd a new impeller...
Tel. 888-531-7253
Dec 13, 2011 | Vacuums
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL is shooting dust out from the roller when I try to vacumn
This is a sign that the bag is full or there's a clog in the air flow piping. Check behind the brush for clogs and remove if there is. Open the cloth bag, remove the paper bag, and check inside the tube. If no blockage is visible, drop a coin or marble down the opening and see if it rolls out. If not, there's a clog that needs removed. You can use an air pressure hose to blow it out..
Feb 16, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL upright vacuum is blowing air instead of sucking air.
I've solved the problem! I had exactly the same problem, with dust being sucked up properly and then some blown out where the bag connects. The XL machine has a hinged plastic dock for the bag, which slides in the dock and you then close the hinge, there's a slight click and the velcro keeps it shut. The problem is that the plastic dock is not behind the ridge, but is in front. So when you start up the bag connection is pushed forward. So:
Undo zipper, open dock hinge and push it back squeezing the panel on the cloth bag. One side will go behind the ridge and you need to push it firmly, opening it a bit if you can. It will go behind that ridge all the way round. You'll see now that the dock is firmly in place, and can be hinged closed as you did before. But instead of the joint being loose, the bag is now tight.
Mine now works fine... thanks to fixya for encouraging me to fix it! I was close to binning the machine. But it sucks well, and I don't go for bagless... like my dirt packaged for disposal. And if you're a farmer, try farmideas.co.uk !!!!
Nov 25, 2010 | Oreck XL Deluxe U3700 Bagged Upright...
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Rollers are to low and tearing up carpet.
unfortunatly you cant adjust the height on that type of machine, and new carpet no matter how good or expensive can shed for up to a year, the best thing would be to buy a cheap carpet rake ( not a garden rake ) that would get up all that fluff.
Sep 11, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Tear in hose
Try EBay because there's always a seller with a reconditioned hose on offer.
Jul 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
99 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
