Question about Frigidaire PLD4460REC Stainless Steel Dishwasher
PLD4460REC START BUTTON
It seems like the touch pad controls work sometimes then not. the start button wont enguage the any cycles. if i take the door apart then put it back together a connection is made and then the start button will engage. then when its done running its cycle its back to taking it apart again. well not that even doesnt seem to work.
  • 1003 Answers
SOURCE: LOCK ON & SHORT RUN PLD3460RDC1
REPLACE POWER CONTROL BOARD
Posted on Jan 18, 2008
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
  • 3247 Answers
SOURCE: It seems when I pushe button to start nothing
Some fault in the dishwasher is causing it to believe the door is not locked.
I would check the door lock.
check this youtube video out for the location of the door switch.
http://www.youtube.com/watch?v=2CqFZ-Ud0nE&feature=related
(quality of video may not be the best but gives an idea of its location).
If you can give me the exact model number I can find out more details of the problem you are having.
Posted on May 12, 2010
marka19
  • 1430 Answers
SOURCE: Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Posted on May 21, 2010
  • 1531 Answers
SOURCE: My Frigidaire Dishwasher FDB1050RES2 gets
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Posted on Dec 29, 2010
Can't select cycle and won't start.
you didn't mention the model number , but I can tell you some models wont start if there's no rinse agent in the dispenser , also for stuck controls a trick that works is to find the breaker for washer in your power panel and click it off for one minute then back on this will force a reset of controls
Jan 22, 2016 | Dishwashers
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
PANASONIC Microwave Inverter #NN-SD697S. Everything works except the START button. Works sometimes, and not other times. Checked outlet, all was good.
This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
Sep 11, 2013 | Panasonic NN-S251 Microwave Oven
Start button wont respond
If all the other buttons work except the start button, you have a faulty touch pad that will need to be replaced. Below is a link to a video you will want to download so you can see how to replace the touch pad.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/control-repair-whirlpoolkitchenaidkenmoremaytagjenn-air-amana-dishwashers/
Good Luck
Mar 01, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher stopped and will not start
Try jigling the ribbon cable that is connected to the control panel. These ribbon cables sometimes fail. Also check the fuse on the control board to see if it is blown.
Jan 02, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
Lights are on, but wont start
The water pump can hum and still have a defective coil.
Jan 13, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishwashers Logo
29 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
