Question about KitchenAid KT2651X Epicurean Stand Mixer
Manual for kitchenaid 475 watt epicurean stand mixer
SOURCE: Power On Problem
if you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Posted on Feb 09, 2009
  • 22 Answers
SOURCE: Kitchenaid pro stand mixer will not turn on
How comfortable are you with electrical parts? With the mixer UNPLUGGED and the switch ON measure resistance between the (flat) plug pins. If it's infinite (no meter movement) which is to be expected, there is an open circuit. The switch could be open or the wire to the switch could be disconnected (improbable) or the motor could be burned out and open (not very probable).
Maybe you could take the switch to a shop and have it tested.
This is not really a solution, just step 1.
Posted on Mar 14, 2009
  • 143 Answers
SOURCE: My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Posted on Oct 12, 2009
  • 143 Answers
SOURCE: Problem for KitchenAid 300 Watts KSM90 Ultra Power
This is common problem among kitchenaid mixers. If you are hearing no motor sound what so ever, The likely cause is the carbon brushes are worn or gone completely, and will need to replaced, they are located at the left and right sides of the unit and only fit ONE way. part number for both brushes is W10260958 and comes one in a package. These are a wearable part and when gone will not create an electrical field for the motor to run. If however these are visually OK, the next probable cause of this will be the motor control board, this can cause a great deal of electrical burning smell when it goes. part number for the board is W10119326. The board can be replaced but does require some know how of the unit.Hope this helps
Thanks
Posted on Nov 06, 2009
hslincoln
  • 235 Answers
SOURCE: my epicurean mixer (5quart) stand mixer sounds
KAY – You don’t mention how long you’ve had your mixer or how intensely you use it, which would be helpful in assessing your question. Our first KA mixer we got in May 1989, seemed ‘whisper’ quiet compared to the replacement 6 qt Pro mixer our children got SWMBO for Christmas in 2006. The new mixer was so noisy that my wife called Kitchenaid to complain. The wonderful KA ‘Helpers’ explained that KA had changed to making all metal gears in their mixer transmissions as opposed to having one plastic gear (intended to fail instead of burning the motor out). That change from plastic to metal is then main reason your KA mixer seems to be much louder. You should be able to judge if your noise level has increased or stays the same during normal use. Since you stated that you don’t notice any overheating of the mixer I would say that the noise level is appropriate and wouldn’t be overly concerned at this point. That being said, if you hear a change in the noise level – usually louder, it could be indicative of mechanical issues in the transmission, which is what finally happened our mixer. One of the gear teeth broke and the agitator froze up. But that is another story…
I hope this helps. Good luck! Howard – Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Posted on Nov 28, 2009
Does the epicurean have an attachment for ice cream maker?
The Model: the Kitchenaid KAICA attachment will work with all Kitchenaid mixers 4.5 to 8 quart models both tilt head and bowl lift.
Aug 03, 2014 | KitchenAid KT2651X Epicurean Stand Mixer
My handle on KitchenAid KT26S1X Epicurean Stand Mixer is jammed and won't lift or lower bowl. Can you advise?
I'm not familiar with that particular model but the common cause of that fault on the ones I do work on is a broken or cracked lift lever inside the stand. You need to remove the stand from the motor housing. 4 screws going up through the stand into the underside of the motor casing at the back. That will expose the lift lever mechanism for you to identify the problem.
Jul 14, 2014 | KitchenAid KT2651X Epicurean Stand Mixer
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
How do I fix a wobbly head on my Kitchenaid Epicurean stand mixer?
Tip it upside down on a towel and tighten up the hinge retaining screw right up inside the pedestal.
Jun 30, 2013 | KitchenAid Food Mixers
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Sep 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid pro stand mixer will not turn on I has been sitting for 3 months without being used. It is a 475 watt bowl lift 6 qt mixer. about 3 years old.
Feb 27, 2009 | KitchenAid K45SS Classic Stand Mixer
Power On Problem
Check to see if the contact points on the control board are working. Adjust the screws at the top of the control board until the contacts make contact. That should fix your problem.
Feb 13, 2009 | KitchenAid KP2671 Professional 6 Series...
Power On Problem
Nov 29, 2008 | KitchenAid KT2651X Epicurean Stand Mixer
KitchenAid KT2651X Epicurean Stand Mixer Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
