Question about Archos ARCDisk 20GB 4200rpm 480Mbps USB 2.0 USB 2.0 External (500455FT) Hard Drive
My Arc Disk 20 is suddenly no longer recognized by my computer and is making a clicking noise. I assume that it is failing but the light is still on. How can I recover info from that drive!
  • 19,396 Answers
Clicking noise means hard drive physical damage. When that happens the data inside hard drive is lost.
If data is very important it can be sent to a recovery facility with a clean room 100, that is a special room where hard disk can be opened. The repair is over $600, and does not guarantee success.
Unless the data inside is really important, data inside hard disk (when clicking) is considered beyond recovery.
Posted on Jan 03, 2009
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 28, 2012 | Western Digital WD Passport 250GB Portable...
My Hitachi Touro 500gb suddenly did not work? no light indicator and not recognized by the computer..
Hi,try to use other usb cable,and insert it also to other usb port of your computer.But if its still not working..go to my computer right click..see the manage,..see the disk management..there you found your hard disk but if doesnt appear on it..it means that your har disk was dead or defective already..thanks
Aug 20, 2011 | Hitachi 500GB Touro Mobile USB 20 HDD Hard...
My hard has all of sudden is not being picked up by my pc or anything for that matter. The power light is flashing on it so I'm thinking it might be the power supply. What do you think ?
Sometimes it could be that it's not registering the letter for the drive. If you hear a chime when you plug it into the computer and turn it on, it is being recognized by your system.
If that is the case. Right-click on your "My Computer" icon, and click on Manage. Then go to "Disk Management". There, it will list your hard drive. You can distinguish it from your computer's hard drive by the size, and normally your computer's hard drive is set to Drive 0 by default.
Once you identify it, you can right-click and "Assign Letter Drive" and that should fix it.
If it does not chime (first make sure that the sound is on). You can try and see if there is a clicking, or a whirling noise. A whirling noise is a good sign. A clicking noise is not. If you hear nothing, then something between the connector to the hard drive inside is bad or the cord connecting the drive to the computer is bad. If you narrow this down, you can normally get the right cause.
I hope this helps.
Please Rate
Jul 08, 2011 | Western Digital Wd Elements Se 1tb...
My external hard drive wont show in my computer but it is recognizing it in disk manager
Hi, is the drive clicking, or making any noise?
are the lights on the drive blinking?
try the drive in another computer, if all fails i think you might need to go to your local PC Store
Mar 02, 2011 | Hitachi Computers & Internet
I have a Que!M3 60GB external hard drive. All of a sudden it is making clicking noises and is not recognized by my computer. Help! This has all of my pictures saved on it!
I assume that your operating system is on another hard drive. If so, try powering down your PC, disconnecting the external drive from the computer's USB port, powering back on and then connecting the drive to a different USB port.
If your computer still does not see the drive, I'm afraid the drive has failed. You might try taking the drive to a PC technician who may have utility software which will enable him to recover your pictures.
If you believe that this information was helpful to you please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 10, 2010 | QPS Que! USB 2.0 Drive CD-RW Burner
Machine not recognized by computer it just is makign a clicking noise
i got the same problem. let me know if you figure it out. except mine stoped making the noise eventually, but still wont recognize.
May 23, 2009 | LaCie Computers & Internet
Drive not being recognized, making weird noises?
I really hope I'm dead wrong on this one. But from the little bit you've described so far, my first guess would be that the loud clicking noise you're hearing is what is known as the 'click of death'.
From Wikipedia: "Click of death" is a term that became common in the late 1990s referring to the clicking sound in disk storage systems that signals the device has failed, often catastrophically." In other words, get out your original purchase receipt and/or warranty (if still valid) and get it replaced or your money back.
KM
Jan 22, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
No recognize
The drive will need to be extracted. The enclosure and/or drive has failed and is causing your computer to fail. Remove the drive carefully from the enclosure and test it in a good, known working stable enclosure...
www.drivesavers.com
keep me posted
Oct 29, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Computers & Internet Logo
245 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
