Question about Exercise & Fitness
Pacemaster pro elite treadmill giving error code 22
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
SOURCE: I just put a new belt on my Pro-Form treadmill.
Hi there
sanjay treadmill repair professional from india
you have done some mistake when you fixed the new belt.
You have a speed sensor problem.
CHECK
1.Front roller sensor usually a magnetic one for broken wire or for larger space between the magnet and the sensor.
i) Sensor is Usually 2 wire and magnet is fixed on to the roller.
ii) Magnet can dislocate from its place check the magnet for attraction by taking a screw driver.
iii) Chcec gap between the magnet and the sensor on the frame. Gap should be betwwen 3mm to 5mm.
2. If roller sensor is not present then there is alternative sensor on the motor ususlly a multi holed plate revolves between the sensor.
i) It is usually has 3 wires.
Check for the connections on the motor control board.
If not solved then mail me on sanjay_phil@yahoo.co.in
Posted on Oct 02, 2009
SOURCE: my sportsart 6150 treadmill gives an error code 1
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
Posted on Feb 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
Pacemaster pro elite INCLINE MOTOR DOES NOT WORK
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 02, 2017 | Exercise & Fitness
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
I have a PaceMaster Pro treadmill. I'm getting a dead sensor error message. Where is the RPM sensor on this treadmill? And how do you replace it?
It would be easier to help if I knew the exact model of the treadmill. Here is a link to what a speed sensor looks like.
http://www.treadmilldoctor.com/speed-sensor
You will most likely have to remove the cover on the bottom part of your treadmill to see it.
Aug 17, 2014 | Exercise & Fitness
Treadmill belt will not move
This can be caused by a few things...call for service 877-805-1030
Jan 03, 2014 | PaceMaster Gold Elite Treadmill Deck
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Pacemaster pro plus error code 20
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience. http://electro-medical.blogspot.com/
Dec 24, 2012 | Exercise & Fitness
Looking for a user manual for a pacemaster proplus treadmill
I have a pdf of the Owners Manual for a PaceMaster Pro-Plus Treadmill. I am attempting to upload it to www.manualsonline.com, so if you still want it, hopefully they will have it soon.
May 08, 2012 | Exercise & Fitness
Exercise & Fitness Logo
288 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
